concatenating and Char data types (headache!)
Hey Guys,
I am working with the MySQL library which required an SQL query to be in the form of a char.
char QUERY_SQL[] = "UPDATE gps_stat.raw_inputs SET snr=snr+1 WHERE id=1";
which basically requests to connect to the database and updates a counter. A bit later in the program the query is executed.
my_conn.cmd_query(QUERY_SQL);
(it likes a char type)
The problem is I would like to throw more then just a static query at it. I would like to have some static text and dynamic data (external sensor) put together to make the query.
I had looked at using string data first with multiple fields all concatenated together to form one big string which then got converted to a char but this didn't work and I suspected it wasn't going to be very memory friendly.
String QUERY_SQL = String("UPDATE gps_stat.raw_inputs SET snr=" + String(DATA[0]) + " WHERE id=1");// concatenating three strings
(DATA[0] is the reference to my sensor data for that particular second)
Does anyone have any suggestions? Can I concatenate multiple char fields into one char field or is there any easier way to go from string to char?
Cheers,
Snip
There are 3 libc functions to handle concatenation of strings.
  • size_t strlcat (char *, const char *, size_t)
  • char * strncat (char *, const char *, size_t)
  • char * strcat (char *, const char *)
Be careful not to overrun your buffers
documentation
I think that sprintf would work as you want to put the data into your char array, as long is its not floats.
Thanks guys, I'll have a muck around with those functions and see how I go.
There are also AVR-specific string functions (usually with the suffix "_P") that allow you concatenate constant strings held in flash memory.
No. It requires the data to be in the form of a char ARRAY. Big difference.
