concatenation: string vs String?
Hi guys. I have some code that takes a character array, but I need to build it dynamically by joining three Strings together. What I have works well enough, but I'm wondering if it would be worthwhile to try and eliminate Strings altogether.
The code I have:
Devices[current_Device] is an array of two Strings containing the device IDs for two bluetooth devices.
//Create the character array to pass to the Serial1.write function
    String AT_String = "AT+RNAME? " + Devices[current_Device] + "\r\n";
    char charBuf[AT_String.length()+1];
    AT_String.toCharArray(charBuf, AT_String.length()+1);
Do you think I should set it up to not use Strings? If so, any ideas to help get me started?
Why? I can't think of a single instance where sending/printing all three individually will not work just as well.
Hmmm...I hadn't thought of that. So, until the device receives the CR and LF signals, it just adds onto the current command?
So....something like this?
Serial1.write("AT+RNAME? ");
serial1.write(Devices[current_Device]);
Serial1.write("\r\n");
That depends on the device, but, yeah, usually.
