conditional include based on processor type
hi,
i want my program to run on a mega2560 or a due, depending on the user’s choice. because the due does not have EEPROM, i will use the DueFlashStorage library, but i do not want to include the library when the code is compiled for a mega2560.
how can i determine the processor of the current board? i already tried the following, but without success:
  1. based on the code of the ArduinoBoardManager library. compiling for the due works fine, but when i select the arduino mega board, the library is still included.
#if defined __AVR_ATSAM3X8E__
  #include <DueFlashStorage.h>
#endif
#ifdef __AVR_ATmega2560__
  //nothing to do
#else
#endif
  1. based on response #8 in this thread: http://forum.arduino.cc/index.php?topic=113656.0 . same problem as 1)
#ifdef __AVR_MEGA2560__
  //nothing to do
#else
#endif
My list shows the DUE processor defined as “SAM3X8E”, not as “AVR_ATSAM3X8E”.
Have you tried:-
#if defined __SAM3X8E__ // DUE
#endif
What IDE version do you use? There was a bug about the #include directive always being processed, this was fixed few months ago, so try with latest IDE.
wergor:
Maybe try this:
// this data borrowed from Nick Gammon's "ATmega fuse calculator"
// http://www.gammon.com.au/forum/?id=11653
const uint64_t sigs[] = {
	0x1E910B,0x1E9207,0x1E930C,0x1E9108,0x1E9206,0x1E930B,
	0x1E920A,0x1E930F,0x1E940B,0x1E950F,0x1E940A,0x1E9508,
	0x1E960A,0x1E9608,0x1E9703,0x1E9704,0x1E9801,0x1E9802,
	0x1E9382,0x1E9482,0x1E9389,0x1E9489,0x1E958A,0x1E9488,
	0x1E9587,0x1E9705,0x1E910A,0x1E920D,0x1E9007,0x1E9307,
const char *names[] = {
	"ATtiny24","ATtiny44","ATtiny84","ATtiny25","ATtiny45","ATtiny85",
	"ATmega48PA","ATmega88PA","ATmega168PA","ATmega328P","ATmega164P","ATmega324P",
	"ATmega644P","ATmega640","ATmega1280","ATmega1281","ATmega2560","ATmega2561",
	"At90USB82","At90USB162","ATmega8U2","ATmega16U2","ATmega32U2","ATmega16U4",
	"ATmega32U4","ATmega1284P","ATtiny2313A","ATtiny4313","ATtiny13A","ATmega8A",
	"Not found",
// AVR signature reader & chip identifier
// (c) 2016 Roger A. Krupski <rakrupski@verizon.net>
// Free code - GPL3 license
void setup (void)
	Serial.begin (115200);
	uint8_t x, y, addr;
	uint64_t signature = 0;
	char buffer[32];
	// get AVR signature bytes
	// signature bytes are at 0, 2 and 4
	for (addr = 0; addr < 3; addr++) { // read the 3 bytes
		signature <<= 8; // slide them into the uint64_t
		signature |= boot_signature_byte_get (addr * 2);
	y = (sizeof (sigs) / sizeof (*sigs));
	for (x = 0; x < y; x++) { // check through all
		if (sigs[x] == signature) { // if there's a match
			break; // exit, X==index into chip name (or "not found" if not found).
	// we only print 6 hex characters since a signature is 3 bytes
	sprintf (buffer, "AVR Signature is: 0x%06lX\n", signature); // print signature
	Serial.print (buffer);
	sprintf (buffer, "AVR Part is: %s\n", names[x]); // print CPU name
void loop (void)
	// nothing
It’s a full demo, but all you need is the part that gets you the signature value. If you get 0x1E9801, it’s a MEGA 2560.
I don’t know, however, what this code would do on a DUE… it may crash it. Try and see if this helps.
Krupski:
Maybe try this:
// Gammon Forum : Electronics : Microprocessors : Atmega Fuse Calculator sketch
const uint64_t sigs = {
// this data borrowed from Nick Gammon’s “ATmega fuse calculator”
const char *names = {
“ATtiny24”,“ATtiny44”,“ATtiny84”,“ATtiny25”,“ATtiny45”,“ATtiny85”,
“ATmega48PA”,“ATmega88PA”,“ATmega168PA”,“ATmega328P”,“ATmega164P”,“ATmega324P”,
“ATmega644P”,“ATmega640”,“ATmega1280”,“ATmega1281”,“ATmega2560”,“ATmega2561”,
“At90USB82”,“At90USB162”,“ATmega8U2”,“ATmega16U2”,“ATmega32U2”,“ATmega16U4”,
“ATmega32U4”,“ATmega1284P”,“ATtiny2313A”,“ATtiny4313”,“ATtiny13A”,“ATmega8A”,
“Not found”,
// (c) 2016 Roger A. Krupski rakrupski@verizon.net
void setup (void)
uint8_t x, y, addr;
char buffer[32];
if (sigs == signature) { // if there’s a match
break; // exit, X==index into chip name (or “not found” if not found).
sprintf (buffer, “AVR Signature is: 0x%06lX\n”, signature); // print signature
sprintf (buffer, “AVR Part is: %s\n”, names); // print CPU name
void loop (void)
// nothing
It's a full demo, but all you need is the part that gets you the signature value. If you get 0x1E9801, it's a MEGA 2560.
I don't know, however, what this code would do on a DUE... it may crash it. Try and see if this helps.
There’s one thing missing from the code above.
This:-
#include <avr/boot.h>
But isn’t it only useful at runtime, rather than at compile-time for conditional compilation?
OldSteve:
This:-
Strange. I don’t have <avr/boot.h> in the code and it compiles for me… and I found out why… I have it in my Arduino.h file. Oops… sorry.
To answer your question, yes it works at runtime. I don’t have any experience with the DUE, so I just put this out in case it would help… I wasn’t sure exactly what the OP needed, so I guessed. :slight_smile:
Krupski:
It’s a handy little utility. I’ve saved a copy for future reference/use. Thanks for putting in the effort.
(And I’ve never used a Due either.)
guix:
i was using 1.6.5r2, updating to 1.6.7 fixed the issue. Thanks!
OldSteve:
Have you tried:-
#endif
you are right, SAM3X8E is the correct label. where did you find that information?
Krupski:
Maybe try this:
its not possible to compile for the mega if the DueFlashStorage library is included, so checking at runtime is not an option.
wergor:
It might be in a different place for you, now that you've upgraded, but for me using V1.6.5, I originally found it in "\Arduino\libraries\Firmata\Boards.h"
Here's the list that I have:-
Found in "\Arduino\libraries\Firmata\Boards.h":-
__AVR_ATmega328P__ : UNO, Arduino Duemilanove, Diecimila, and NG
__AVR_ATmega168__ : Arduino Duemilanove, Diecimila, and NG
__AVR_ATmega8__ : old Arduinos
__AVR_ATmega1280__ : Mega
__AVR_ATmega2560__ : Mega
__SAM3X8E__ : DUE
__AVR_AT90USB162__ : Teensy 1.0
if defined(__AVR_ATmega32U4__) && defined(CORE_TEENSY) : Teensy 2.0
if defined(__MK20DX128__) || defined(__MK20DX256__) : Teensy 3.0 and 3.1
if defined(__AVR_AT90USB646__) || defined(__AVR_AT90USB1286__) : Teensy++ 1.0 and 2.0
__AVR_ATmega32U4__ : Leonardo
ARDUINO_LINUX : Intel Galileo
if defined(__AVR_ATmega644P__) || defined(__AVR_ATmega644__)|| defined(__AVR_ATmega1284P__) : Sanguino
__AVR_ATmega645__ : Illuminato
__AVR_ATtiny45__
__AVR_ATtiny85__
__AVR_ATtiny24__
__AVR_ATtiny44__
__AVR_ATtiny84__
*** Also see "\Arduino\hardware\arduino\avr\bootloaders\stk500v2\avr_cpunames.h"
OldSteve:
found it. thanks!
