conditional on a *char? Need help with syntax
I'm using the CC300o and Adafruit server library to set up a web server for simple control though different web paths that I send along.
The var path is a *char (char pointer).
When I access the server with http://xxx.xxx.x.xx/b the following will show Path: /b
Serial.print(F("Path: ")); Serial.println(path);
so we know that /b is stored in *path.
my question is how would I accomplish the following:
if(path == '/b')
//do something
Also in this case I only need the 2nd char so the following would cool to know how to accomplish:
if(path[1] == 'b')
//do something
I've gotten the sketch to work with:
String pathString = String(path);
if(pathString == "/b")
val = 'b';
but I'd rather not have the overhead of the String class if I don't need it.
THANKS!!!!!!
check out strcmp() string compare
http://www.cplusplus.com/reference/cstring/strcmp/
also strstr() to find the position of a substring ...
http://www.cplusplus.com/reference/cstring/strstr/
So you have a function that returns the path, and this function returns a char *?
If that is the case, the char * can be used without the need of the String class, ie:
if( !strcmp( path, "/b" ) )
// or if path contains a lot more data before or after that string:
if( strstr( path, "/b" ))
That worked like a champ tammytam! THANKS!!!!
While I have it fresh in my mind I'd like to ask this also, as it's the next step in my project...
Let's sat I start with 3 ints...
int val1;
int val2;
int val3;
now in this path *char I populate it with 9 numbers. For example...
I access http://xxx.xxx.x.xx/123456789
resulting in *path = /123456789
how would I parse this to:
val1 = 123
val2 = 456
val3 = 789
Thanks again!
I'm using a server library that returns a *char of the path I try to access.
for example if I access http://xxx.xxx.x.xx/123456789
int val1;
int val2;
int val3;
val1 = 123
val2 = 456
val3 = 789
The format would always be 9 numbers.
Thanks again!
This is a little bit of a hack, but it should work:
  char *path = "/123456789";
  char buff[4];      // Need room for null
  int i;
  int index = 0;
  int vals[3];
  int max = strlen(path);
  for (i = 1; i < max; i += 3) {
    strncpy(buff, &path[i], 3);
    vals[index++] = atoi(buff);
  for (i = 0; i < 3; i++)
    Serial.println(vals[i]);
