Conditional preprocessor directive is seen in .h and not in .cpp
The conditional preprocessor directive is seen in .h and not in .cpp. Is there an issue?
Arduino 1.8.9 Same issue in Sloeber IDE.
my ino:
#include <Arduino.h>
#include <HardwareSerial.h>
#define PRINT_OK
#include "conditionnal_includes_print.h"
Test test;
 test.printSerialTestFromInclude();
 test.printSerialTestFromIncludeOk();
my header .h (conditionnal_includes_print.h):
class Test
  public:
   void printSerialTestFromInclude(void);
   void printSerialTestFromIncludeOk(void)
      Serial.
#ifdef PRINT_OK
      println("arduino ide OK see the directive define from header");
#else
      println("arduino ide NO see the directive define from header");
#endif
my .cpp (conditionnal_includes_print.cpp)
void Test::printSerialTestFromInclude(void)
      Serial.
#ifdef PRINT_OK
      println("arduino ide OK see the directive define from cpp");
#else
      println("arduino ide NO see the directive define from cpp");
#endif
the log serial is:
The .ino contains the #define. The .cpp does not.
It's normal that .ino and .h contain #define and not .cpp? If you have many class with the same #define dependency you must copy paste all your #define in each cpp you have?
Even stranger... If a function is declared in the header file, the SAME method of the SAME instance will produce DIFFERENT results depending on what was defined when the declaration was seen.
Called from INO:
Called from Header: MethodDeclaredInHeader(): PRINT_OK is defined.
Called from Header: MethodDeclaredInSource(): PRINT_OK is NOT defined
Called from INO:
Called from Source: MethodDeclaredInHeader(): PRINT_OK is NOT defined.
Called from Source: MethodDeclaredInSource(): PRINT_OK is NOT defined
sketch.ino
#define PRINT_OK
#include "test.h"
Test test;
  Serial.println("Called from INO: ");
  test.bothFromHeader();
  test.bothFromSource();
void loop() {}
test.h
class Test
  public:
    void MethodDeclaredInSource(void);
    void MethodDeclaredInHeader(void)
      Serial.print("MethodDeclaredInHeader(): ");
#ifdef PRINT_OK
      Serial.println("PRINT_OK is defined.");
#else
      Serial.println("PRINT_OK is NOT defined.");
#endif
    void bothFromSource();
    void bothFromHeader()
      Serial.print("Called from Header: ");
      MethodDeclaredInHeader();
      MethodDeclaredInSource();
test.cpp
#include "test.h"
void Test::MethodDeclaredInSource(void)
  Serial.print("MethodDeclaredInSource(): ");
#ifdef PRINT_OK
  Serial.println("PRINT_OK is defined");
#else
  Serial.println("PRINT_OK is NOT defined");
#endif
void Test::bothFromSource()
  Serial.print("Called from Source: ");
MENIER:
Yes, it is normal for a .cpp file to not include #define statements in your .ino.
If you have a bunch of .cpp and .h files that all depend on one #define, put that #define in a .h and include it everywhere it is needed. Then you only have to change that one .h file.
If i well resume the #define in .ino as no effect on any .cpp . but only on the .h
