Hi
Spent some time without resolving problem with 'If-else if' constructs when programming a simple current sensor application and Hitachi display (early stages of development). The first code (part) works effectively - accurately displaying sensed currents correctly in milli Amps if sensed current is <0.5 and in Amps for sensed currents > 0.5A . However, in the second example current is not displayed (display blanked) despite measured current being in the 'Boolean True' range >=0.5A and <=1A. I have checked forum and other Internet sources and cant resolve the problem; the syntax seems correct and the variable being tested is a 'real' type. As a beginner programmer to C++ is there an obvious error in my code? I am using an Arduino Nano processor.
Thanks in anticipation
Hi
Thanks for your comment. Yes, suppose code readability - indentations hangover from VB / VBA days. Note your auto format advice. Ampersands in Print commands used to concatenate display text and variables. So would display:
"Current: 500mA" say, on same display row.
Checked in circuit load current with ammeter and within test parameters. Used 'Serial monitor' - code not shown to monitor converted ADC values, again within test parameters.
Re string / variable concatenation in C++, is there an alternative approach that I am not aware of when sending text strings and variables to a display? When used in this way they do work. Serial Monitor is the debugging tool part of the Arduino IDE - s orry misleading here.
Regards
Mike
Why do you need to concatenate anything?
They would also work, and make it look like you knew what you were doing, as:
