I programmed something very simple on an ESP32 devkit V1 card, however my conditionals don't work. Every time I test it in my terminal I have the character string according to what I expected but it does not access within the conditional.
The incoming data may have invisible characters with it. Like carriage return ('\r') and/or line feed ('\n'). "ON\r\n" is not equal to "ON".
Try adding this:
mensaje = Serial.readString();
// add this line to remove invisible characters
mensaje.trim();
Serial.print(mensaje);
Read the forum guidelines to see how to properly post code.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Thanks, I just tested it with the trim function and apparently it entered the conditional as expected, However my GPIO does not go into a positive state (High) I tried to change it from GPIO however I never had positive voltage, do you think it is a failure in my ESP32 board?
By the way, thank you very much for the advice to upload the code properly to the forum, it was my first time and I was a bit lost.
#include <Arduino.h>
#define RELE 14
String mensaje;
pinMode(OUTPUT,RELE);
digitalWrite(RELE,HIGH);
if(Serial.available()){
mensaje.trim(); // line to remove invisible characters such as '\n'
Serial.println(mensaje);
if(mensaje=="ON"){
Serial.println("TURN ON RELE");
else if(mensaje=="OFF"){
digitalWrite(RELE,LOW);
Serial.println("TURN OFF RELE");
else{
Serial.println("Invalid");
mensaje ="";
The Output in the terminal is like this (It was set to 115200 baud and with both carriage return and new line):
Okay, I loaded your code to test it and unfortunately it didn't put the pin high... Now I think my board is damaged then, although it seems a bit strange to me because a few days ago I had tried other programs with it and it had worked correctly .
Thanks for your time.!
PD:Do you think it could be the way I'm uploading the file to the board? image|690x388
If the upload method worked before, then no. If you are unsure about what you did before, then you will have to find the right settings.
But I don’t think that’s your problem.
Use the same program but move the relay or LED to a different pin. Sometimes one port bit, one I/O pin that is, can be damaged, but other pins will be fine.
Doe that board have a build in LED you could try?
Are there any indications of failure to upload?
I think if there is damages to the board, they haven’t killed it completely.
Actually I tested the relay in several Outputs, and none of them appears to work as expected.
And no, when I upload the code everything seems right an I don't get any errors.
I tested with a ESP32 DEV KIT and LED and it worked OK after the change. I don't know the specs on their relay, whether it will work at 3.3V. That can be determined by just testing it with 3.3V.
I only caught it after uploading the code to my ESP32 and it would not work. I could not understand why until I really looked at the code. It had to be something like that.
Oh, that can explain everything...
I already checked and the last code I told you @alto777 was in the correct order as @groundFungus said: pinMode ('some name', Output) so that code worked fine, but idk what happen to make me think that It was backwards. And of course I will test it with the ESP32 (Although it will be until Monday because they already closed the laboratory and I do not have a ESP32 board of my own I'm going to buy one anyways... )
I will inform you although I believe that everything will be solved
