Conditions being met but the if statement isn't working
I am trying to elicit a response whenever I click a button 5 times under a certain amount of time. Before I get to that, I need to make sure that the conditions work and I am getting the right time. So I am trying to print out the time whenever the conditions are met.
The two conditions are that n == 5 (n increases by 1 whenever I push the button) and that the time is under 15,000. I know that the first condition is being met because the monitor prints out n whenever I press the button. The second condition should also be met because I have timed it myself.
But even when both of these conditions are met, the If statement is not printing out what I want it to print out. Help please.
int ledPin = 13;
int buttonPin = 2;
int buttonState;
int lastButtonState = 0;
int buzzerPin = 9;
int buzzerState;
int n = 0;
unsigned long previous_time = 0;
const int interval = 15000;
  pinMode(ledPin, OUTPUT);
  pinMode(buttonPin, INPUT);
  pinMode(buzzerPin, OUTPUT);
  unsigned long current_time = millis();
  unsigned long button_time = current_time - previous_time;
  buttonState = digitalRead(buttonPin);
  delay(50);
  if (buttonState == HIGH)
    digitalWrite(ledPin, HIGH);
    digitalWrite(ledPin, LOW);
  if (buttonState != lastButtonState)
      n = n + 1;
      Serial.println(n);
      if (n >= 5)
        n = 0;
      //  Serial.println(current_time);
      if (n == 1)
        previous_time = millis();
      //  Serial.println(previous_time);
    lastButtonState = buttonState;
  if (n == 5 && button_time <= interval)
How can n be 5 here if you reset it to zero immediately when it reaches 5 here?
`const int interval = 15000;`
Always use unsigned long for any variables associated with millis() or micros().
the way to find the error is:
to printout all details right before the if-condition
Serial.print( F("n:") );
Serial print (n);
Serial.print( F("  button_time:") );
Serial.print(button_time);
Serial.print( F("  interval:") );
Serial.print(interval);
Serial.print( F(" n ==5:") );
Serial.print(n ==5);
Serial.print( F("   button_time <= interval") );
Serial.print(button_time <= interval);
of course this will take 5 minutes time to write down the code
compare to how long it took to get an answer posted
best regards Stefan
