hello I have connected to Arduino Uno 24 volts for a few seconds and has stopped responding guess habre burned something and want to know who has been to change or save the remaining pieces if irreparable
if I could say as checking components or if the only thing that has happened is a matter of software and I have to burn a bootloader or try
the computer recognizes me a plate even if the other had not since connected by pin 5v and gnd
I have already tried to climb the program and blink when climbing gives me error
here I leave esque error but not many tracks just tells me that does not answer the plate
hola le he conectado a arduino uno 24 voltios durante unos segundos y ha dejado de responder supongo que habre quemado algo y querria saber que ha sido para poder cambiarlo o salvar el resto de piezas si es irreparable
si me pudieran decir como comprobar los componentes o si lo unico que ha sucedido es cosa de software y tengo que quemarle un bootloader o que probar
el ordenador me reconoce una placa aunque la otra no ya que las tenia conectadas por los pin 5v y gnd
ya he probado a subir el programa blink y a la hora de subir me da error
aqui dejo el error aunque no esque de muchas pistas solo me indica que no responde la placa
error.txt (18.5 KB)
