Conect a 4*3 keypad to an uno Arduino
Hi
i am a bit new to using Arduino .I am dealing with a project which I should implement on the uno Arduino. we should connect a keypad and LCD and some other stuff to the device. The problem is that I need every gates in the Arduino and keypad and LCD will take too many inputs/outputs.
I count that if I reduce the keypad input to (1-3) instead of 7 I will have no problem.
So please help and guide me,how to connect the keypad to 1-3 gate of my Arduino UNO.
thanks
The easiest way is probably to add an i²c "backpack" to your LCD. This will need to use pins A4+A5 or SDA+SCL (they are in fact the same pins and are connected on the Uno board). But it will free up 4 pins. There are versions of the LCD library that will work with the i²c backpack.
Another option is to connect your keypad to an i²c chip which gives you more input/output pins. Then the keypad can share the same 2 pins as the LCD. This works because i²c is a "bus" system that can have many devices attached to the same 2 pins. That would free up another 7 pins!
Thank you so much.
I use the first step you say( and it's working). the second would be fantastic but I didn't find any solution for that.do you have any idea or know any tutorial link for implementing it in proteus(the 2nd solution)
