I have this ADXL345 Which has 5V 3V3 and VS instead of VCC as the one in the Sparkfun guide . So how should I connect it to a regular 5V Nano?
Try connecting 5V, GND, SDA, SCL as usual.
jremington:
Do you mean 5V instead of VCC?
Connect "5V" on the sensor to "5V" on the Arduino
jremington:
So it is 5V tolerant? Can skip the pullup resistors and the level regulators that are usually needed?
The SENSOR is certainly not 5V tolerant.
Don't buy undocumented modules, unless you are willing to sacrifice a few, trying to figure out how they work.
Thanks for the help. I am really a beginner.
is there's a way to recognize 5V tolerance - I guess you would see a level shifter on the board. This part seems to have exactly the same structure board but is described as "Support 5V/3.3V voltage input". Or maybe also this one isn't 5V tolerant?
The link leads to a log in screen.
If the board has level shifters, it will most likely be using tiny MOSFETs, with a resistor on source and drain. You will have to reverse engineer it to be sure.
It is silly for a beginner to buy undocumented parts from Ali Express, just because they are a few pennies cheaper. You get zero support, and possibly counterfeit, used or rejected chips to boot. Complete waste of time and money!
Got it. Maybe do you have a link for a serious 5v tolerant ADXL345?
Adafruit, among others, sells an ADXL345 module with level shifters built in.
There is nothing special about the ADXL345, though.
