Hi all, was wondering if there is a way to configure xbee modules without a usb/ftdi adapter. Here in greece they cost about 20-25euro and buying one from ebay will make about 20 days to come. So
my setup:
i got an arduino mega 2650
2 xbee series 2 modules (2mw)
a mega sensor shield v2.3 from dfrobot that can hold up to three modules
i tried to discover the modules in xctu without success, obviously :P.
i also tried to put the arduino in reset mode (by shorting reset and gnd). still cannot discover the modules.
i also tried to reset the modules (short pin 5 and 8 from datasheets).
in xctu i set : 9600 baud, 8 data bits, parity none, stop bits 1, flow control none/hardware. here i must state that xctu can see the mega on com 7. so i think my mega is ok. plus the green led under each module on the shield is constantly green.
Load empty sketch into Arduino. Then connect Xbee to pin 0 and 1 and try XCTU. You should try all the baud rates, or is your Xbee brand new? Hw reset will reset it to values saved in NV memory, so there could be written different baud as 9600.
