Configuring my USB port in Linux C++ for communication with my Arduino UNO
Hey guys,
I'm trying to make a C++ (Linux) application which communicates with my Arduino UNO. Problem is, I cannot for the life of me understand how to configure it "properly".
The configuration I want, is essentially the excact same thing as the Arduino IDE sets when using the Serial Monitor.
This is my function which opens the connection with my Arduino.
std::cout << "Opening device " << port << ": ";
    /* Open the file descriptor in non-blocking mode */
    device = open(port.c_str(), O_RDWR | O_NOCTTY | O_NDELAY);
    if (device == -1) {
        std::cerr << "failed" << std::endl;
        return;
    } else
        std::cout << "connected" << std::endl;
    /* Set up the control structure */
    struct termios options;
    /* Get currently set options for the tty */
    tcgetattr(device, &options);
    /* Set custom options */
    /* 9600 baud */
    cfsetispeed(&options, B9600);
    cfsetospeed(&options, B9600);
//    /* 8 bits, no parity, no stop bits */
    options.c_cflag &= ~PARENB;
    options.c_cflag &= ~CSTOPB;
    options.c_cflag &= ~CSIZE;
    options.c_cflag |= CS8;
//    // Ignore break
//    options.c_cflag |= IGNBRK;
//    // Do not map CR to	NL on input
//    options.c_cflag &= ~INLCR;
//    options.c_cflag &= ~IMAXBEL;
//    /* no hardware flow control */
//    options.c_cflag &= ~CRTSCTS;
//    /* enable receiver, ignore status lines */
//    options.c_cflag |= CREAD | CLOCAL;
//    /* disable input/output flow control, disable restart chars */
//    options.c_iflag &= ~(IXON | IXOFF | IXANY);
//    /* disable canonical input, disable echo,
//    disable visually erase chars,
//    disable terminal-generated signals */
//    options.c_iflag &= ~(ICANON | ECHO | ECHOE | ISIG);
//    /* disable output processing */
//    options.c_oflag &= ~OPOST;
//    /* no minimum time to wait before read returns */
//    options.c_cc[VTIME] = 0;
    /* commit the options */
    tcsetattr(device, TCSANOW, &options);
    std::cout << "Waiting 3 seconds for serial device ..." << std::endl;
    usleep(3000 * 1000);
    /* Flush anything already in the serial buffer */
    tcflush(device, TCIFLUSH);
Can somebody guide me towards which settings I need to communicate with the Arduino, the same way the Arduino IDE does?
In case it is not essential to use C++ this Python - Arduino demo may be of interest.
In any case the same general approach should be used in any language.
...R
