configuting wifi via serial monitor(ssid and password)
So, i’m using NodeMCU v1.0, and i wonder if i can change the SSID of the wifi via serial monitor…
I was expecting this similar output from serial monitor :
Input your SSID
"nodemcuAP"
Input your Password
"flippedtable"
Configure complete
This is what i’e tried so far, using different source
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h>
SoftwareSerial BTserial(13, 15); // RX, TX
String ssid = "indeed"; //nama SSID
String password = "11111111";
void(* resetFunc) (void) = 0;
int x = 0;
int counter = 1;
const long baudRate = 9600;
boolean NL = true;
  awal:
  BTserial.begin(baudRate);
  WiFi.softAP(ssid, password);
awal:
  while (x < 1)
    Serial.println("Initializing");
    BTserial.println("Initializing");
    x++;
  String s1 = Serial.readString();// s1 is String type variable.
  Serial.print("Received Data => ");
  Serial.println(s1);//display same received Data back in serial monitor.
  if (BTserial.available())
    String b = BTserial.readString();
    if (b.indexOf("reboot") >= 0)
      Serial.println("rebooting");
      BTserial.println("rebooting");
      x = 0;
      goto awal;
    else if (b.indexOf("ping") >= 0)
      Serial.println("pong");
      BTserial.println("pong");
    else if (b.indexOf("ssid") >=0)//this is what i've tried changing ssid
      ssid = b;
      x=0;
      resetFunc();
// i seriously have no idea about Wifi and stuff
i hope it’s clear enough…
if it’s not i will reply ASAP
Thank you
really?    goto awal;
setup() is where the set up is done. Keep the loop for what needs to happen all the time.
I would suggest to study Serial Input Basics to handle this
