Hello everyone,
I'm developing a stetch to use handle the comunication between an arduino master and another one that is the slave, using Modbus over RS485. This code will use ArduinoModbus library for it.
This code uses another library that I made that has two functions, name ON and OFF, that are called like className.ON() and className.OFF(). However, ArduinoModbus has #define ON 1 and #define OFF 0, this gimme the error bellow.
I find it really strange given that those methods are within my class.
Any help is appriciated.
In file included from C:\Program Files (x86)\Arduino\libraries\ArduinoModbus\src/ModbusClient.h:24:0,
from C:\Program Files (x86)\Arduino\libraries\ArduinoModbus\src/ModbusRTUClient.h:25,
from C:\Program Files (x86)\Arduino\libraries\ArduinoModbus\src/ArduinoModbus.h:23,
from C:\Users\user\AppData\Local\Temp\Temp1_CustomLibrary.zip\CustomLibrary\examples\ModbusRTUMasterHoldingRegister\ModbusRTUMasterHoldingRegister.ino:22:
C:\Program Files (x86)\Arduino\libraries\ArduinoModbus\src/libmodbus/modbus.h:58:12: error: expected unqualified-id before numeric constant
#define ON 1
C:\Program Files (x86)\Arduino\libraries\CustomLibrary\src/CustomLibrary.h:30:10: note: in expansion of macro 'ON'
void ON(uint8_t_pin);
C:\Program Files (x86)\Arduino\libraries\ArduinoModbus\src/libmodbus/modbus.h:54:13: error: expected unqualified-id before numeric constant
#define OFF 0
C:\Program Files (x86)\Arduino\libraries\CustomLibrary\src/CustomLibrary.h:46:10: note: in expansion of macro 'OFF'
void OFF(uint8_t_pin);
C:\Users\user\AppData\Local\Temp\Temp1_CustomLibrary.zip\CustomLibrary\examples\ModbusRTUMasterHoldingRegister\ModbusRTUMasterHoldingRegister.ino: In function 'void setup()':
#define ON 1
C:\Users\user\AppData\Local\Temp\Temp1_CustomLibrary.zip\CustomLibrary\examples\ModbusRTUMasterHoldingRegister\ModbusRTUMasterHoldingRegister.ino:34:12: note: in expansion of macro 'ON'
className.ON(1);
#define ON 1
C:\Users\user\AppData\Local\Temp\Temp1_CustomLibrary.zip\CustomLibrary\examples\ModbusRTUMasterHoldingRegister\ModbusRTUMasterHoldingRegister.ino:36:12: note: in expansion of macro 'ON'
className.ON(2);
