Conflict between Arduino Giga and Giga Display Shield
Hi there! My first post :slight_smile:
It looks like the ECC chip on the Giga R1 uses the same i2c bus as the Touch Panel on the Giga Display Shield: Wire1.
The ECC library (ArduinoECCX08) sets the Wire1 clock frequency to 1Mhz.
The Touch Panel library (Arduino_GigaDisplayTouch) sets the Wire1 clock frequency to 400khz.
I use the ECC chip for SSL connections via MQTT. And when I enable the Touch Panel the MQTT client wont connect about 50% of the times. I get a network error.
I suspect this is because the Touch Panel hijacks the Wire1 bus and the SSL client can not get information from the ECC chip.
My setup is as follows:
Hardware:
  • Arduino Giga R1
  • Arduino Giga Display Shield. Default connection on the back of the Giga R1
  • Arduino Ethernet 2 Shield. Default connection on the top of the Giga R1
I have tried a lot over the last couple of months to fix this. I am a bit new to c++ and Arduino tho, so this is probably my fault :slight_smile:
I also use the SD card on the Ethernet shield, but this, as far as I know, communicates via SPI.
I have tried creating locking logic for Wire1 with communication via RPC.
I have tried setting interrupt priority.
I have tried starting everything from scratch.
I have tried disabling everything else in my project.
I have tried to modify the libraries in question as well as extend them.
I have checked that it is not the MQTT broker that is rejecting the connection.
I also tried doing the same project on a MKR WiFi with an MKR ETH shield and ran into the same issue when I tried to add a keypad via i2c as it seems to conflict with the ECC chip.
Here is my chat with ChatGPT from the last two days regarding this issue.
What am I missing here?
M7 main:
#include "main.h"
String currentCPU() {
    if (HAL_GetCurrentCPUID() == CM7_CPUID) {
        return "M7";
        return "M4";
    while (!Serial){};
    // Arduino GIGA needs some time here for some reason to enable Serial monitor
    Serial.print("Booting ");
    Serial.print(currentCPU());
    Serial.println(" chip");
    Serial.println("SETUP DISPLAY");
    setupDisplay();
    RPC.begin();
    // Let RPC bind some essential functions on M4
    delay(1100);
    setupTouch();
    loopDisplay();
    String buffer = "";
    while (RPC.available()) {
        buffer += (char)RPC.read();  // Fill the buffer with characters
    if (buffer.length() > 0) {
        Serial.print(buffer);
M7 display:
#include "display.h"
Arduino_H7_Video Display(480, 800, GigaDisplayShield);
unsigned long lastDisplayUpdate = 0;
unsigned long displayUpdateDelay = 10; // Max (min) every 5 ms
void handleContactItemPress(lv_event_t * e) {
    Serial.println("Contact clicked!");
    lv_obj_t * table = lv_event_get_current_target_obj(e);
    uint32_t col;
    uint32_t row;
    lv_table_get_selected_cell(table, &row, &col);
    // TODO: figure how to use user data here instead of text value
    const char *text = lv_table_get_cell_value(table, row, col);
    Serial.println(text);
void setupDisplay() {
    Display.begin();
    // Setup lvgl
    lv_init();
    // Setup ui exported from eez studio
    ui_init();
    constexpr int numberOfContacts = 12;
    lv_obj_t * contactsTable = objects.contacts_table;
    lv_table_set_column_width(contactsTable, 0, 476);
    lv_table_set_row_count(contactsTable, numberOfContacts); /*Not required but avoids a lot of memory reallocation lv_table_set_set_value*/
    lv_table_set_column_count(contactsTable, 1);
    lv_obj_add_event(contactsTable, handleContactItemPress, LV_EVENT_VALUE_CHANGED, NULL);
    // We do not need this after the next eez studio export
    lv_obj_set_style_text_font(contactsTable, &ui_font_playfair_48, LV_PART_MAIN | LV_STATE_DEFAULT);
    for (int i = 0; i < numberOfContacts; i++) {
        lv_table_set_cell_value_fmt(contactsTable, i, 0, "Mike Portnoy");
        // TODO: figure out how to get this value with lv_table_get_cell_user_data it is a void pointer
        // std::string userId = "123";
        // lv_table_set_cell_user_data(contactsTable, i, 0, &userId);
void loopDisplay() {
    // const unsigned long now = millis();
    if ((millis() - lastDisplayUpdate) > displayUpdateDelay) {
        lv_timer_handler();
        ui_tick();
        lastDisplayUpdate = millis();
void displayDoorOpen() {
void displayInvalidCode() {
M7 touch:
#include "touch.h"
// Uses Wire1, same as ECC chip, sets clock to 400khz which interferes with ECC chip and makes SSL connections unstable
Arduino_GigaDisplayTouch TouchDetector;
void setupTouch() {
  Serial.println("SETUP TOUCH");
  TouchDetector.begin();
M4 main:
#include "main.h"
    return "M7";
    return "M4";
  RPC.begin();
  RPC.print("Hello from M4");
  RPC.println(millis());
  RPC.println(currentCPU());
  RPC.println("MAIN SETUP");
  RPC.println("ECC SETUP");
  eccSetup();
  RPC.println("ECC ENSURE LOCK");
  ensureEccLock();
  const String serial = getSerialNumber();
  RPC.println("S/N: " + serial);
  // Ethernet requires ecc to get serial number for consistent MAC
  const IPAddress localIp = ethernetInterfaceSetup();
  RPC.println("IP: " + localIp.toString());
  delay(500); // Allow Ethernet to stabilize
  RPC.println("NTP SETUP");
  // Bear SSL needs NTP time to make http requests
  ntpSetup();
  getAndCacheWorldTime();
  const String utcTime = getUTCTime();
  RPC.println(utcTime);
  RPC.println("SD SETUP");
  sdCardSetup();
  RPC.println("SSL SETUP");
  sslClientSetup();
  RPC.println("ENSURE REGISTRATION");
  ensureCsrAndId(); // Get id from API and generate CSR
  ensureIoTSetup(); // Setup certificate, policies and Thing in aws iot and save certificate
  RPC.println("MQTT SETUP");
  mqttClientSetup();
  RPC.println("All good");
  ensureMqttClient();
  loopMqtt();
M4 ECC:
#include "ecc.h"
void eccSetup() {
    int retryCount = 0;
    constexpr int maxRetries = 5;
    // Uses Wire1, same as Touch panel, sets clock to 1Mhz which collides with touch panel that wants to run at 400khz
    while (!ECCX08.begin() && retryCount < maxRetries) {
        RPC.println("No ECCX08 present!");
        retryCount++;
    if (retryCount == maxRetries) {
        RPC.println("ECC initialization failed after retries.");
        // TODO: Handle failure, e.g., reboot or enter safe mode
String getSerialNumber() {
    String serialNumber = ECCX08.serialNumber();
    return serialNumber;
int getRandomNumber(const long max) {
    const int res = ECCX08.random(max);
    return res;
bool ensureEccLock() {
    if (!ECCX08.locked()) {
        RPC.println("ECCX08 is not locked, locking ...");
        if (!ECCX08.writeConfiguration(ECCX08_DEFAULT_TLS_CONFIG)) {
            RPC.println("Writing ECCX08 configuration failed!");
            return false;
        if (!ECCX08.lock()) {
            RPC.println("Locking ECCX08 configuration failed!");
            return false;
    RPC.println("ECCX08 is locked :)");
    return true;
M4 ethernet:
#include "ethernet_interface.h"
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 0, 177);
IPAddress myDns(192, 168, 0, 1);
// Placeholder
uint8_t uniqueMac[] = {0, 0, 0, 0, 0, 0};
IPAddress ethernetInterfaceSetup () {
    getPersistentUniqueMac(uniqueMac);
    IPAddress localIp;
    // EthernetClass::init(5); // MKR ETH Shield
    EthernetClass::init(ETH_CS_PIN); // GIGA + Ethernet 2 shield
    // start the Ethernet connection:
    RPC.println("Initialize Ethernet with DHCP");
    RPC.print("With MAC: ");
    for (const unsigned char i : uniqueMac) RPC.print(i, HEX);
    RPC.println();
    if (EthernetClass::begin(uniqueMac) == 0) {
        RPC.println("Failed to configure Ethernet using DHCP");
        // Check for Ethernet hardware present
        if (EthernetClass::hardwareStatus() == EthernetNoHardware) {
            RPC.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
            while (true) {
                delay(1); // do nothing, no point running without Ethernet hardware
        if (EthernetClass::linkStatus() == LinkOFF) {
            RPC.println("Ethernet cable is not connected.");
        // try to configure using IP address instead of DHCP:
        EthernetClass::begin(uniqueMac, ip, myDns);
        RPC.print("DHCP assigned IP ");
        RPC.println(EthernetClass::localIP());
        localIp = EthernetClass::localIP();
    // give the Ethernet shield a second to initialize:
    return localIp;
M4 ssl:
#include "ssl_client.h"
EthernetClient ethernetClient;
BearSSLClient sslClient(ethernetClient);
void sslClientSetup() {
    // The SSL lib needs unix time from a NTP server to validate something
    ArduinoBearSSL.onGetTime(getUnixTime);
void sslClientSetCertificate(const String& certificate) {
    const size_t str_len = certificate.length();
    char cert_str[str_len];
    certificate.toCharArray(cert_str, str_len);
    sslClient.setEccSlot(0, cert_str);
M4 MQTT:
#include "mqtt_client.h"
unsigned long lastMqttUpdate = 0;
unsigned long mqttUpdateDelay = 250;
constexpr char broker[] = SECRET_IOT_ENDPOINT;
MqttClient mqttClient(sslClient);
String getDeviceIotTopic() {
    return ioAccessLockTopicDomain + "/" + getDeviceId();
void mqttClientSetup() {
    const String certificate = sdCardReadFile(certificatePemFileName);
    if (certificate.length() == 0) {
        RPC.println("No IOT certificate found");
        return;
    sslClientSetCertificate(certificate);
    const String deviceId = getDeviceId();
    mqttClient.setId(deviceId);
    mqttClient.onMessage(onMessageReceived);
// In main loop
void ensureMqttClient() {
    if (!mqttClient.connected()) {
        RPC.println("MQTT not connected");
        connectMQTT();
void loopMqtt() {
    if ((millis() - lastMqttUpdate) > mqttUpdateDelay) {
        mqttClient.poll();
        lastMqttUpdate = millis();
void connectMQTT() {
    RPC.print("Attempting to connect to MQTT broker...");
    RPC.println(broker);
    int retryCount = 0;
    const int maxRetries = 5;
    while (!mqttClient.connect(broker, 8883)) {
        int errorCode = mqttClient.connectError();
        RPC.print("MQTT connection failed. Error code: ");
        RPC.println(errorCode);
        switch (errorCode) {
            case 1:
                RPC.println("Error: Incorrect protocol version.");
            case 2:
                RPC.println("Error: Invalid client identifier.");
            case 3:
                RPC.println("Error: Server unavailable.");
            case 4:
                RPC.println("Error: Bad username or password.");
            case 5:
                RPC.println("Error: Not authorized.");
            default:
                RPC.println("Error: Unknown error.");
        if (retryCount >= maxRetries) {
            RPC.println("Max retries reached. Giving up.");
            return;
        int backoffTime = pow(2, retryCount) * 1000;
        RPC.print("Retrying in ");
        RPC.print(backoffTime);
        RPC.println(" ms");
        delay(backoffTime);
        retryCount++;
    RPC.println("Connected to MQTT broker.");
    // subscribe to a topic
    const String topic = getDeviceIotTopic();
    RPC.println("Subscribing to topic: " + topic);
    mqttClient.subscribe(topic);
void publishMessage(const String& subTopic, const String& input) {
    RPC.println("Publishing message");
    String const topic = ioAccessControlTopicDomain + "/" + subTopic;
    RPC.println(topic);
    constexpr bool retained = false;
    constexpr int qos = 1;
    constexpr bool dup = false;
    JsonDocument inputDoc;
    inputDoc["message"] = input;
    String payload = "";
    serializeJson(inputDoc, payload);
    const size_t contentLength = payload.length();
    mqttClient.beginMessage(topic, contentLength, retained, qos, dup);
    mqttClient.print(payload);
    mqttClient.endMessage();
void onMessageReceived(const int messageSize) {
    while (mqttClient.available()) {
        payload += static_cast<char>(mqttClient.read());
    handleMqttMessage(payload);
void onMqttDisconnect(int reason) {
    RPC.print("MQTT disconnected. Reason: ");
    RPC.println(reason);
The M4 processor usually freezes on "Attempting to connect to MQTT broker..." or it gives an error code "-2". Both from the connectMQTT() function.
Maybe start at the beginning by reading the pinned post re 'How to get the most from this forum'. One thing to know is diagrams, data sheets, ALL code in code tags etc is not just preferable to word salads, but is the standard.
Have you tried changing line 28 in ArduinoACCX08/src/ECC08.cpp from 1MHz to 400 kHz? The chip should accept that as it's the normal setting for avr
update: this looks related (maybe) Hard faulting on Giga R1 with display shield · Issue #69 · arduino-libraries/ArduinoECCX08 · GitHub
Once it fails it would seem that the next I2C request causes a hard fault. That maybe the next time the ECCX08 lib is called or maybe when another I2C device is accessed.
Do you get any hard fault crashes?
Noted and updated!
Yeah, I have tried changing that line. That results in an errorCode -2 from connectMQTT() about 50% of the times I try to reboot.
In regards to the hard fault crashed, I'm not quite sure what that means, but the github issue mentions that it would suddenly crash after boot, but my issue happens at boot.
I should mention that the times it does get past boot and I try to use the ECC again for for example hashing, it crashes. But that can be due to a lot of things since I have been focusing on this issue.
I'd raise an issue on both the display and ecc repos, neither should be setting the clock, that's your job. I don't have the display or use the ECC, but I know someone that does and they REALLY know their stuff @schnoberts
First of all before the cannon comes out, welcome to the forum!
Also, you've done a great job providing code and lots of info, helping others help you.
Now...
Oh please. Don't add one more factor to a mess. Seriously.
There are no settings for this? Modifying a library direct really calls for spaghetti on the scene.
Disclaimer: I have no knowledge about the specific problem at hand here, this is just general insight and experience. Hope you'll get it sorted. :upside_down_face:
@steve9 :blush: I'm really a newbie in this microcontroller space, but thanks for the kind words.
@jonasbarsten , I'm afraid my experience is similar. I started with a very similar stack to you. Arduino MQTT and HTTP clients, the Arduino port of BearSSL, ECCX08, RPC library. I am using a Giga Display Shield with Giga R1 WiFi though rather than Giga + Ethernet shield.
TL;DR - I didn't solve the issue. I have written up my experiences using the above stack in case it has any relevance. I apologise in advance for my tendency to ramble :). I have put a second reply regarding locking just in case you missing some places you’d need a lock.
Where my system is different architecturally is I run the networking and UI on the M7 and I run the "semi-real-time" stuff on the M4. The M4 streams data to the M7 and the M7 streams data over the internet and provides rich UI (using lvgl) for working with the system. That has some trade offs, but they are right for the project I am helping on .
When reading this reply it's worth bearing in mind my biases. My experience on software engineering is largely writing various flavour of high performance software on optimised *nix machines. I know nothing about electronics and anything I've picked up on embedded stuff has been via helpful people on this forum - of which there are many - or by picking my way through code trying to work out why it doesn't work :slight_smile: I'm also inclined to switch horses if I think one is lame rather than spend weeks trying to fix it. I'm quite functionality orientated. Anyway, biases stated, let's move on.
In the specific case of ECCX08 I experienced random crashes if I left my device running long enough. When I pointed my debugger at it these were always in DisplayTouch driver code. I tried a lot of things and in the end wrote a test sketch purely on the M7. In my test I setup the GigaDisplay, DisplayTouch and ECCX08 and in loop I called lv_timer_handler() and then did some ECCX08 stuff, in my case read some slots, generate a public key. I timed these calls and what I found was at one point an ECCX08 call would take a long time and the very next call would hard fault (crash). The crash would always happen, sometimes after a few minutes, sometimes 5 hours. Like you I suspect a clash between the Touch and ECCX08.
I'd get crashes quicker if I didn't power cycle the device. You probably know this (I didn't) but I2C is fragile in the face of soft resets as the I2C clients are stateful and don't drop their state without a power cycle. This means if you soft reset at the "right" time an I2C client can have a different view of the bus state from the master. Crashes result. I think this is compounded by the Wire library error handling not being the absolute gold standard. This basically means replication of tests in this area need to span a power cycle and not just rely on soft resets.
In the end (which is probably not helpful to you), I gave up. I had function points to create and working out how to fix these libraries was becoming a distraction. I have a hunch the DisplayTouch driver might be doing I2C stuff in an async process to the main thread that was poking the ECCX08, but it's only a hunch. Maybe it does that itself or maybe it's the way lvgl is calling the driver. That could be another area of exploration.
I've had issues with other parts of the stack you list as well. RPC was really unstable - now a lot better due to a major PR fixing a lot of issues. It does however have a lack of error return codes so writing robust code with the API is impossible in my opinion and the slow speed makes it difficult to use in my use-case. I ended up with bipartite ring buffers in shared memory and the M4 and M7 do message passing over these rings. It's fast, simple and easy to understand. If you do this it's important to know that the M4 doesn't have a cache and the M7 does. This means you have to do cache invalidation on the M7 to get the latest M4 update or push an M7 update to the M4 in a timely fashion - or it means you mark the shared memory region as non-cacheable.
I found the Arduino networking stack unreliable in the face of the sort of edge cases you get from TCP connections on the Internet - and that's despite a lot of work by good people to improve it. This seemed compounded by use with the Arduino BearSSL port - you can see in the error handling paths where the BearSSL and Networking libraries interface that things weren't straightforward. I think the core of that issue is the Networking stack in the Arduino core is designed for all manner of hardware and thus carries complexity in it that is not required in a device as powerful as the Giga and that complexity has driven defects.
Having abandoned the ECCX08 (I don't have a secure vault but I've some workarounds for that and I live with it) I ditched the Arduino Core based network stack and BearSSL and use mbedtls (the one that comes with mbed) which sits on top of the underlying mbed network API. I used the FreeRTOS HTTP/MQTT libraries because they've been thoroughly tested and integrating them into my Arduino app was trivial. Since I made these moves (and built a custom mbed with some TCP parameters advised by @steve9 in this thread Consistent http failures on every 5th request) the system has been rock solid. Well, except for some occasional white screen on soft reset issue I get every couple of weeks (Random white screen on start up) :smile:
My conclusion from this journey is the mbed Arduino Core is relatively immature and not ready for a really reliable system. I think that just reflects Arduino's roots as a hobby / learning platform rather than an industrial strength platform (there's a place for both of these things in the world) and perhaps aggressive timelines to get STM32 support to market.
Having joined a project where the Arduino stack and Giga were chosen, my general strategy nowadays is to use mbed directly where I can and adopt Arduino libraries sparingly and only after a thorough code review. I know this exposes me to the mbed EOL.
I'm sorry this isn't a helpful "just do this one thing and ECCX08 will play nicely" but I figured my journey might be useful.
All this being said, if you persevere and get the ECCX08 working in this stack please reply on this thread and let us know.
Andy
I don't think there's any harm in forking a library and fixing it if you know what you're doing :slight_smile: I fork all Arduino libraries (and the mbed Arduino Core) I use as a default so when I need to patch them I can. I'm not a dabbler though, I know my way around a C/C++ compiler.
Not at all, as long as you keep track of the changes. :relieved:
On a positive note I do have shared access to Wire2 running across M4 and M7 so there isn’t anything intrinsically problematic with sharing I2C. I use a HAL HSEM semaphore to do the locking for that and it works well. I do this with a timeout so I can abandon the lock attempt if it takes too long, skip what I’m going to do and log the fact.
Assuming the issues using touch and eccx08 on just one processor are specific to my incompetence (possible) I do have some thoughts - you may have tried these:
As you note above, you want to do networking (which requires the ECCX08 and hence Wire for initial TLs handshake) on the M4 and run lvgl with display touch on the M7 which requires the Wire bus. This probably requires you consider protecting calls to lv_timer_handler with an HSEM and any TLS connection access with HSEM at least as an initial conservative approach for test. You will also need to protect the M4 setup code that accesses the ECCX08 with the same HSEM as the M4 maybe in setup when the M7 is already in loop. I haven’t checked but I imagine ECC08 is only used in initial TLS handshake so you might get away with only protecting reconnects and initial connect on the M4.
That means you’re going to be serialising lvgl and networking which might suck if you are reconnecting due to a network issue or peer close.
Also consider moving the display touch setup before RPC.begin so it’s already setup before the M4 starts.
Finally, the clocks on some of these Giga’s (eg mine) do not always keep good time so make sure you do NTP periodically.
This is the test code that always crashes eventually. I've just confirmed this again with the latest Arduino IDE and library updates.
13:05:12.698 -> 7464 208
13:05:12.897 -> key gen failed
13:05:12.897 -> 7464 207
.... the test had run for 128 minutes before it failed.
You will note that lv_init() is not called. This is because it's called in display_.begin() thus:
int Arduino_H7_Video::begin() {
#ifdef HAS_ARDUINOGRAPHICS
  if (!ArduinoGraphics::begin()) {
    return 1; /* Unknown err */
  textFont(Font_5x7);
#endif
  /* Video controller/bridge init */
  _shield->init(_edidMode);
  #if __has_include("lvgl.h")
    /* Initiliaze LVGL library */
    lv_init();  <<<<<<--------------------------- LV_INIT CALLED HERE
#include <Arduino.h>
#include "Arduino_GigaDisplayTouch.h"
#include "Arduino_H7_Video.h"
#include "ArduinoECCX08.h"
#include "lvgl.h"
Arduino_H7_Video display_( 800, 480, GigaDisplayShield ) ;
Arduino_GigaDisplayTouch touch_;
// Still crashes with the optimiser disabled
#pragma GCC optimize ("O0")
#else
// Check the lv_init() path will happen in _display.begin() we
// error if it will not.
#error "NO LVGL"
#endif
  delay(2000); // Give monitor time to connect before we output
  display_.begin();
  touch_.begin();
  // Testing calling timer handler before ECCX08 setup
  lv_timer_handler();
  if (!ECCX08.begin()) {
    Serial.println("WTF");
    lv_timer_handler();
    while (true);
    Serial.println("OK");
    lv_timer_handler();
byte device[25];
byte buffer[256];
byte publicKey[64];
  lv_timer_handler();
  auto then = millis();
  if (!ECCX08.readSlot(static_cast<int>(10), buffer, 72)) {
    Serial.println("slot 10 read failed");
  if (!ECCX08.readSlot(static_cast<int>(10) + 1, buffer, 36)) {
    Serial.println("slot 11 read failed");
  if (!ECCX08.readSlot(static_cast<int>(10) + 2, device, 72)) {
    Serial.println("slot 12 read failed");
  if (!ECCX08.generatePublicKey(static_cast<int>(0), publicKey)) {
    Serial.println("key gen failed");
  Serial.print(time(nullptr)); Serial.print(" "); Serial.println(millis() - then);
... and here's how you might use HSEM for locking:
class I2CWire2Lock
public:
  bool waitFor( int32_t timeoutMillis )
    while ( timeoutMillis > 0 && !acquire() ) {
      delay( 50 );
      timeoutMillis -= 50;
    return locked_;
  bool acquire()
    locked_ = ( HAL_HSEM_FastTake( SemaphoreID ) == HAL_OK );
    return locked_;
  void release()
    if ( locked_ ) {
      HAL_HSEM_Release( SemaphoreID, 0 );
      locked_ = false;
  ~I2CWire2Lock()
    if ( locked_ ) release();
private:
  static constexpr unsigned SemaphoreID{ 15 };
  bool locked_{ false };
