Can any one help me with my programming? I am getting the conflict between libraries Pinchangint.h and Softwareserial.h
I am using Arduino UNO (Pin 0 and 1) , Arduino GSM Shield (Pin 2 and 3 and 7), water flow sensor to measure water flow using using Pinchange interrupts (Pin 4), RFID module using software serial (pin 8 , 9 and 10)
My code is as below
#include <PinChangeInt.h>
#include <SoftwareSerial.h>
//Parallax RFID Reader
#define RFIDEnablePin 8 //Pin that enables reading. Set as OUTPUT and LOW to read an RFID tag
#define RFIDSerialRate 2400 //Parallax RFID Reader Serial Port Speed
//Using SoftwareSerial Library to locate the serial pins off the default set
//This allows the Arduino to be updated via USB with no conflict
#define RxPin 9 //Pin to read data from Reader
#define TxPin 10 //Pin to write data to the Reader NOTE: The reader doesn't get written to, don't connect this line.
SoftwareSerial RFIDReader(RxPin,TxPin);
String RFIDTAG=""; //Holds the RFID Code read from a tag
String DisplayTAG = ""; //Holds the last displayed RFID Tag
#define sensorPin 4
volatile int flow = 0;
volatile int flow1 = 0;
volatile int flowTime;
int flowattempt = 0;
byte second = 0;
// WATER FLOW SENSOR
pinMode(sensorPin, INPUT);
PCintPort::attachInterrupt(sensorPin, flow3, RISING);
// RFID reader SOUT pin connected to Serial RX pin at 2400bps
RFIDReader.begin(RFIDSerialRate);
// Set Enable pin as OUTPUT to connect it to the RFID /ENABLE pin
pinMode(RFIDEnablePin,OUTPUT);
// Activate the RFID reader
// Setting the RFIDEnablePin HIGH will deactivate the reader
// which could be usefull if you wanted to save battery life for
// example.
digitalWrite(RFIDEnablePin, LOW);
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Hello world!"); // prints hello with ending line break
void flow3()
flow1++;
if (millis() % 1000)
if (second == 60)
second = 0;
second++;
if (second % 2)
flow = flow1 / 7.5;
flowattempt = (flow1 /2) / 7.5;
flow1 = 0;
Serial.print("L/Min ");
Serial.println(flowattempt);
// RFID
if(RFIDReader.available() > 0) // If data available from reader
ReadSerial(RFIDTAG); //Read the tag number from the reader. Should return a 10 digit serial number
//This only displays a tag once, unless another tag is scanned
if(DisplayTAG!=RFIDTAG)
DisplayTAG=RFIDTAG;
Serial.println(RFIDTAG);
//RFID
void ReadSerial(String &ReadTagString)
int bytesread = 0;
int val = 0;
char code[10];
String TagCode="";
if(RFIDReader.available() > 0) { // If data available from reader
if((val = RFIDReader.read()) == 10) { // Check for header
bytesread = 0;
while(bytesread<10) { // Read 10 digit code
if( RFIDReader.available() > 0) {
val = RFIDReader.read();
if((val == 10)||(val == 13)) { // If header or stop bytes before the 10 digit reading
break; // Stop reading
code[bytesread] = val; // Add the digit
bytesread++; // Ready to read next digit
if(bytesread == 10) { // If 10 digit read is complete
for(int x=0;x<10;x++) //Copy the Chars to a String
TagCode += code[x];
ReadTagString = TagCode; //Update the caller
while(RFIDReader.available() > 0) //Burn off any characters still in the buffer
RFIDReader.read();
bytesread = 0;
TagCode="";
I am getting below comply error
Arduino: 1.6.5 (Mac OS X), Board: "Arduino Uno"
SoftwareSerial/SoftwareSerial.cpp.o: In function __vector_3': /Users/miteshjoshi/Desktop/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SoftwareSerial/SoftwareSerial.cpp:227: multiple definition of __vector_3'
Sketch_Mitesh_WaterFlowSensor.cpp.o:/Users/miteshjoshi/Documents/Arduino/libraries/PinChangeInt/PinChangeInt.h:563: first defined here
SoftwareSerial/SoftwareSerial.cpp.o: In function SoftwareSerial::read()': /Users/miteshjoshi/Desktop/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SoftwareSerial/SoftwareSerial.cpp:392: multiple definition of __vector_4'
Sketch_Mitesh_WaterFlowSensor.cpp.o:/Users/miteshjoshi/Sketch_Mitesh_WaterFlowSensor.ino:53: first defined here
SoftwareSerial/SoftwareSerial.cpp.o: In function SoftwareSerial::read()': /Users/miteshjoshi/Desktop/Arduino.app/Contents/Java/hardware/arduino/avr/libraries/SoftwareSerial/SoftwareSerial.cpp:392: multiple definition of __vector_5'
collect2: error: ld returned 1 exit status
Error compiling.
enabled in File > Preferences.
