Conflict between servo and ir master
Hello,
I have a problem because it seems that two of librairies are in conflict. (servo et ir remote master)
Here is the message:
Arduino : 1.8.2 (Windows 10), Carte : "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
libraries\Servo\avr\Servo.cpp.o (symbol from plugin): In function `ServoCount':
(.text+0x0): multiple definition of `__vector_17'
libraries\Arduino-IRremote-master\IRremote.cpp.o (symbol from plugin):(.text+0x0): first defined here
c:/program files (x86)/arduino/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ld.exe: Disabling relaxation: it will not work with multiple definitions
collect2.exe: error: ld returned 1 exit status
exit status 1
Erreur de compilation pour la carte Arduino/Genuino Mega or Mega 2560
Did you google that? Servos use timers. IR sending/receiving uses timers. They can't use the same timer.
Consider using the ServoTimer2 library so that a different timer is used to control the servos.
Yes, I've checked what timer was used by the both but I didn t find. I tried to change some of the timers but it didn t change.
You didn't which timer either library used, so you went an f**ked around with some random timers, but that did not help. Well, color me surprised.
