ndd12
February 1, 2014, 9:53pm
1
Im trying to use both SoftwareSerial and library for PCF8574 chip (downloaded from here: GitHub - skywodd/pcf8574_arduino_library: PCF8574 / PCF8575 Arduino library (version 2.0) ).
On compile IDE show this:
/usr/bin/avr-ld: warning: -z relro ignored.
PCF8574/PCF8574.cpp.o: In function `__vector_9':
/home/ndd/sketchbook/libraries/PCF8574/PCint.h:108: multiple definition of `__vector_9'
SoftwareSerial/SoftwareSerial.cpp.o:/usr/share/arduino-1.0.5/libraries/SoftwareSerial/SoftwareSerial.cpp:306: first defined here
collect2: error: ld returned 1 exit status
So i guess that problem is both libraries try to use same 'vector'. How to solve this? Are there any other 'vectors' (no idea what it is) which i can switch in one library to resolve conflict?
system
February 2, 2014, 1:07am
2
If you have pins 8 and 9 free, you could try using AltSoftSerial instead of SoftwareSerial.
ndd12
February 2, 2014, 8:13am
3
PaulS:
SoftwareSerial is using pin 8 as rx and pin 9 is used by buzzer. So, this conflict is impossible to solve and i have to use other library?
system
February 2, 2014, 11:06am
4
So, pin 8 would be available for use by AltSoftSerial.
And you can't move it? Or won't move it?
It it's can't, then I don't have any other ideas.
It it's won't, then you are shit out of luck.
ndd12
February 2, 2014, 5:19pm
5
PaulS:
Can't. No more free pins. Maybe when i get second PCF8674 chip to move LCD to it. Temporarily im not using PCF8574 lib, just Wire lib.
system
February 2, 2014, 5:32pm
6
ndd12:
PaulS:
Can you tell us what pins you are using, and what you are using them for?
ndd12
February 3, 2014, 10:43am
7
Pins
2-3 => PCF8574
4-7 => LCD
8 => SoftwareSerial RX
9 => buzzer
10 => LCD backlight control
11-12 => LCD
13 => Fan control
system
February 3, 2014, 10:46am
8
So, you have a bunch of pins on the other side of the board that can also be used as digital pins. A0, A1, etc.
ndd12
February 3, 2014, 5:45pm
9
Can i use analog pins as digital? Arent they read-only?
system
February 3, 2014, 5:47pm
10
Yes.
As analog pins, yes. As digital pins, no.
