After tearing my hairs off working with CapSense, I finally came to the conclusion that the errors I was experiencing were coming from the software side, more precisely from the tone() function.
I noticed that when the tone() fonction is called, wether the piezo buzzer is connected or not, CapSense reads a lot of false data. So for the sake of example I stripped down everything;
#include <CapacitiveSensor.h>
CapacitiveSensor cs_7_8 = CapacitiveSensor(7,8);
unsigned long csSum = 0;
unsigned long previousPiezoAlarmInterval = 0;
const int PiezoAlarmInterval = 5*1000;
int speakerPin = 4;
Tone();
long cs =Â cs_7_8.capacitiveSensor(80);
if (cs > 100) {
csSum += cs;
Serial.println(cs);
if (csSum >= 3500) { //Re-Calibrate to avoid tripping off
csSum = 0;
cs_7_8.reset_CS_AutoCal();
csSum = 0; //timeout
Serial.println(cs);
void Tone() {
if (millis() - previousPiezoAlarmInterval >= PiezoAlarmInterval) {
previousPiezoAlarmInterval += PiezoAlarmInterval;
tone(speakerPin, 30, 3000);
So pin 7 is connected to a 10M resistor, which is connected to pin 8. And pin 8 is connected to an antenna.
In the end I worked the bug around using a substitute to the tone() function, but as I could not manage to get the exact tone I wanted I would rather prefer to know how to fix the bug.
