Conflict defining interrupt rutines using RH_ASK
Hello !
I am in the proccess of making a project using hardware we designed ourselves.
Primarily we use the standard avr libraries and a couple of header files we made ourselves.
The car should be able to switch from the automatic driving code driveControl(); and an wireless controllable solution.
The problem is the moment we want to utilize the RH_ASK.h library to make the car controllable wirelessly. I get this error statement
WInterrupts.c.o (symbol from plugin)*: In function attachInterrupt
Error linking for board ATmega2560 (Mega 2560) (Arduino Mega)
(.text+0x0)*: multiple definition of __vector_2
Projekt_endelig.cpp.o (symbol from plugin)*: (.text+0x0): first defined here
(.text+0x0)*: multiple definition of __vector_4
collect2.exe*: error: ld returned 1 exit status
The odd thing is that the RH_ASK driver utilizes the TIMER1_COMPA interrupt, but this infers that it is my external interrupts INT1_vect and INT3_vect that has multiple definitions. Sure enough if I comment out the two external interrupts, the program will compile.
Below is the main program.
I hope anyone has any insight in this problem! :smiley:
Main file:
#define F_CPU 16000000
#include <avr/interrupt.h>
#include <avr/io.h>
#include <util/delay.h>
#include <RH_ASK.h>
#include <SPI.h>
#include "Timer3_driver.h"
#include "driveControl.h"
#include "motor.h"
#include "led.h"
#define ROCKET_SWITCH 22					//Rocket switch PIN
#define TIMER_N 53036						//Timer trappe værdi.
RH_ASK rfDriver;							//Reciever driver objekt
volatile unsigned char reflexCounter = 0;	//Global variable for placement of car
volatile bool state = true;					//Bool state used to control the variable in interrupt routines
void initPortForInt();
//interrupt rutine for the first reflex
//The routine starts the timer and adds 1 to reflexCounter
ISR(INT1_vect)
	if (state)
		state = false;
		startTimerInt(TIMER_N);
		reflexCounter++;
//interrupt rutine for the second reflex
ISR(INT3_vect)
	if (state)
		state = false;
		reflexCounter++;
//Timer overflow routine, to ensure two inputs can't enter at the same time
//Stops timer at sets state to true
ISR(TIMER3_OVF_vect)
	stopTimerInt();
	state = true;
//Setup of all ports and drivers
	//init reciever
	rfDriver.init();
	//Init portB for leds on shield
	initLEDport();
	//init ports for interrupts
	initPortForInt();
	//init timer for reflex
	initTimer();
	//Init motor control
	initMotorPWMandToggle();
	//Init light control
	//Init sound control
	//Init global interrupt
	sei();
	//Led sequence that assures car is ready to go
	initOkay();
	//make sure it starts at 0
	reflexCounter = 0;
	while (digitalRead(ROCKET_SWITCH))
		driveControl(reflexCounter);
	while (!digitalRead(ROCKET_SWITCH))
		uint8_t buf[7];
		uint8_t buflen = sizeof(buf);
		// Check if received packet is correct size
		if (rfDriver.recv(buf, &buflen))
			unsigned char speed[3] = { buf[0],buf[1],buf[2] };
			unsigned char buttonPressed[3] = { (buf[3] - '0'),(buf[4] - '0'), (buf[5] - '0') };
			int sumOfSpeed = atoi(speed);
			if (sumOfSpeed > 200)
				//forward(sumOfSpeed, 0, 0);
				Serial.print("forward: ");
				Serial.print(sumOfSpeed);
				Serial.print("\n");
			if (sumOfSpeed < 200)
				//backward(sumOfSpeed, 0, 0);
				Serial.print("backward: ");
				Serial.print("\n");
			for (int i = 0; i <= 2; i++)
				Serial.print("Button nr. ");
				Serial.print(i);
				Serial.print("\n");
				Serial.print(buttonPressed[i]);
				Serial.print("\n");
			// Message received with valid checksum
			Serial.print("Message Received: ");
			for (int i = 0; i <= 7; i++)
				Serial.print(buf[i] - '0');
				Serial.print(" ");
	//init PORT D pin til input
	DDRD = 0;
	//Pin 46 (PD3) benyttes til INT 3
	//Pin 45 (PD2) benyttes til INT 2
	DDRE = 0;
	//init PORT A pins til input
	DDRA = 0;
	//Pin 22 (PA0) benyttes til Rocket_switch. Bestemmelse af driveControl eller remoteControl
	//initialise interrupt
	//Enable INT2, INT3 interrupt
	EIMSK |= 0b00001100;
	//Enable rising edge interrupt request for INT 2 and INT 3
	EICRA |= 0b11110000;
	//Init Timer interrupts og prescaler
Which Arduino are you using?
You can force it to use Timer 2 instead by enabling the define RH_ASK_ARDUINO_USE_TIMER2 near the top of RH_ASK.cpp
wouldn't that make your life easier?
I'm using a Mega 2560.
I tried that and it gives me the exact same error :confused:
what's this library? does it make use of the ISR for timer 3?
It manually engages the Timer3 in normal mode and sets up interrupt for it.
I use it to create a delay between the inputs of the INT2 and INT3, so reflexCounter can't increment within a specific time limit.
#include <avr/io.h>
void initTimer()
	TCCR3A = 0b00000000;					//init timer3 normal mode
	TCCR3B = 0b00000000;
void startTimerInt(unsigned int N)
	TCNT3 = N;		//trin
	TCCR3B |= 0b00000100;	//prescaler
	TIMSK3 |= 0b00000001;	//set interrupt
void stopTimerInt()
	TCCR3B &= 0b11111000;	//prescaler 0 (no clock)
	TIMSK3 &= 0b11111110;	//Deactivate interrupt
	TIFR3 |= 0b00000001;	//make sure overflow flag is put down
what about.
what does it use ?
According to the AVR datasheet, those two vectors are for two of the external interrupts:
Vector 2 = INT0 (PORTD Bit 0) Pin 21
Vector 4 = INT2 (PORTD Bit 2) Pin 19
The interrupt numbers in the datasheet and __vector__# differ by 1.
__vector_2 = vector 3 in datasheet = INT1
__vector_4 = vector 5 in datasheet = INT3
So: Pin 20 and Pin 18.
Yes these are interrupts i use for other applications. I've tried using INT 2 and 4 and such, and get the same error.
What could cause this? The RH_ASK shouldn't effect these two interrupts
Rather than trying to override the Arduino library by defining external interrupts yourself, just use attachInterrupt().
Change:
to:
    attachInterrupt(2, INT2Handler, RISING);
    attachInterrupt(3, INT3Handler, RISING);
and
ISR(INT1_vect)
	if (state)
		state = false;
		reflexCounter++;
ISR(INT3_vect)
	if (state)
		state = false;
		reflexCounter++;
to
void INT1Handler()
	if (state)
		state = false;
		reflexCounter++;
void INT3Handler()
	if (state)
		state = false;
		reflexCounter++;
I will try this out! Thank you
This worked perfectly! Thank you for the help :smiley:
