Conflict with DS1307,Time, Wire and RF24 library NRF24L01 and DS1307 RTC
Hi all
I wonder if someone could please assist me with how to solve what I suspect is a conflict somewhere between libraries or hardware (????) I'm really not sure at the moment :frowning: and could use a little help.
I current have an Arduino UNO , a DS1307 and an NRF24L01 module connected.
All work perfectly well individually as well as in the following combinations:
Arduino on its own = Working
Arduino + DS1307 = Working
In the current code I would normally see the time and date displayed every second. I can also run most of the examples just fine.
The libraries I am using here are:
#include <Time.h>
#include <Wire.h>
#include <DS1307RTC.h>
Arduino + NRF24L01 = Working
Also working great when using the RF24 library and I am able to run a simple continuous send and transmit without issues. As well as the examples
#include <SPI.h>
#include "RF24.h"
When I connect both the DS1307 and the NRF24L01 it looks like all is good in terms of hardware until I run the code.
I set the code to do a clock update every second as well as a simple transmit of a message on every loop of the ""void loop"".
The code compiles just fine without issues.
The problem is that when I open the serial monitor I see absolutely nothing. It's just blank :frowning:
and the receiving NRF24L01 receives nothing.
//for NRF
#include <SPI.h>
#include "RF24.h"
// Your chosen radio CE,CS pins
RF24 radio(9,10);
uint64_t addresses[] = {
  0xABABABABABLL, 0xC3C3C3C3C3LL};
/****** Configure this for sender or receiver *****/
boolean sender = 1; // Change this from 0 to 1 to switch between sending or receiving sketch
//for DS1307 RTC
#include <Time.h>
#include <Wire.h>
  //DS1307
  while (!Serial) ;
  setSyncProvider(RTC.get);
  if(timeStatus()!= timeSet)
    Serial.println("Unable to sync with the RTC");
    Serial.println("RTC has set the system time");
  //test field for setTime
  Serial.println("Time is now set using setTime");
  setTime(21,30,50,12,4,2015);
  RTC.set(now());
  //NRF24L01
  radio.begin();
  if(sender == 0){
    radio.openWritingPipe(addresses[1]);
    radio.openReadingPipe(1,addresses[0]);
    radio.startListening();
  else{
    radio.openWritingPipe(addresses[0]);    //*Edit to correct address assignments
    radio.openReadingPipe(1,addresses[1]);
    radio.stopListening();
char myArray[] = "This is not a test";
  //*****ALL WORKING UP TO HERE !!
  if (timeStatus() == timeSet) {
    digitalClockDisplay();
  else { //add or change later
    Serial.println("The time has not been set.  Please run the Time");
    Serial.println("TimeRTCSet example, or DS1307RTC SetTime example.");
  //BUT WHEN I ADD THIS IN THE COMPILE IS FINE BUT NOTHING APPEARS
  //IN THE SERIAL MONITOR :-(
  //NRF 24L01
  if(sender == 0){
    if(radio.available()){
      char tmpArray[19];
      radio.read(&tmpArray,sizeof(tmpArray));
      Serial.println(tmpArray);
      delay(200);
  else{
    bool ok = radio.write(&myArray,sizeof(myArray));
    if(ok){
      Serial.println("Transfer OK");
    else {
      Serial.println("Transfer Fail");
void digitalClockDisplay(){
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
I would appreciate and look forward to any help or advice.
D
din4444:
HThe problem is that when I open the serial monitor I see absolutely nothing. It's just blank :frowning:
One possibility would by: OUT OF RAM!
You really waste so much RAM in your sketch, that maybe the 2 KB (2048 bytes) of an UNO might not be enough to handle all the wasted RAM.
At a first step you should use the F-macro for all print commands that have a constant text as parameter.
Instead of wasting RAM:
Use F-macro to save RAM:
Serial.println(F("Unable to sync with the RTC"));
After changing that in your code: Any difference?
Hi Jurs
Thanks a million for your reply.
I appreciate the tip to minimize resource usage so I followed all your advise and definitely gave it a bash.
Initially the used memory after compile was 10,984 bytes.
After making the changes it was 11.058 bytes.
It honest had zero effect on the problem though, so I resorted back to what I had posted.
I re-checked my code, chopped and changed things around and then attacked the hardware side.
I clipped the power leads feeding the DS1307, to check if it was a possible power drain, tested it again and no difference.
Then noticed what looked like a dry joint on the incoming power feed to the DS1307 ... I re-soldered it , plugged it all in and tested....
WHAMMO it's working ...YAY. Even seems faster than time itself :slight_smile: LOL
@ Jurs .... is your suggestion the same as printf() ?
Where exactly is there a saving ? is it in running memory or compiled footprint ?
Thank you once again .. you know when you're at wits end it's always a plus getting a different set of eyes and mind in on things and forces a person to review ones work and thinking.
Take care
And if you enjoy the code example as simple as it is, I would love some feedback from whomever.
D
din4444:
No, the F-macro prints strings directly from flash (program) memory.
If you print string constants without using the F-macro, all the constant strings will be copied from flash memory to RAM memory before the program starts, and will reside there while the program is running.
Especially when printing a lot of text constants, each use of the F-macro can save some bytes of RAM.
The only disadvantage is, that every usage of the F-macro will add a few bytes to the flash/program size.
But as all AVR controllers have much more flash memory (UNO: 32 KB) than RAM memory (UNO: 2 KB), you typically will benefit from the F-macro when your application tends to be short of RAM.
See: Arduino Playground - HomePage
