conflict with Monome driver?
Hi All,
I can't install FTDIUSBSerialDriver_v2_2_9_Intel. I get a message saying I can't because a newer version is installed. I just installed a driver required to set up my Monome (FTDIUSBSerialDriver_v2_2_10). I can't get the ide to run either. I keep getting prompted to re-unzip or download again. Any suggestions?
Thanks! Rob
If you have FTDIUSBSerialDriver_v2_2_10 then you don't need FTDIUSBSerialDriver_v2_2_9_Intel, assuming the first driver is working.
Make sure the driver you have (FTDIUSBSerialDriver_v2_2_10) is actually an Intel version (I assume you are on a Mac) and then select it from the Arduino's menu.
