I tried this simple program. The Oled display works if I remove DCCPacketscheduler, When I use this command, the Oled gives no picture. There is no Error by compiling.
Does anyone know why?
#include <DCCPacket.h>
#include <DCCPacketQueue.h>
#include <DCCPacketScheduler.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
DCCPacketScheduler dps;
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET 4
#define UITIR 5 // Out IR
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
int dccadres = 6;
int teller = 0;
Serial.println(F("start"));
display.display();
Serial.print("F");
Serial.println(teller);
teller++ ;
delay (20000);
The display is not intialized with “display.begin(…)” and you are not displaying anything on it. Did you mind to look at one of the examples for the display?
Trebbie:
display.display();
you should put display.begin("address of the oled or something like that")
Okay sorry, I made the Programm to simple
The real program is thisone.
The problem remains. If I use DCCPacketScheduler dps; the OLED does not work.
If I remove it (and all the dps components) The OLED works.
#include <SPI.h>
#include <Wire.h>
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define UITIR 5 // Uitgang van IR
int dccadres = 6;
int teller = 0;
byte stat[16] = {1,0,0,0,0,0,0,1,0,0,0,0,0,0,0,1};
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3D for 128x64
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
display.display();
delay(2000); // Pause for 2 seconds
// Clear the buffer
display.clearDisplay();
// dps.setup(UITIR);// ************ pinout ******
// dps.setpower(true);
void textdecoder(void) {
display.setTextSize(2); // Draw 2X-scale text
display.setTextColor(SSD1306_WHITE);
display.setCursor(20, 0);
display.println(F("decoder"));
display.display(); // Show initial text
void textadres(void) {
display.setCursor(15, 18);
display.print(F("adres "));
display.println(dccadres);
void textstatus(void) {
display.setTextSize(1); // Draw 2X-scale text
display.setCursor(10, 40);
for(int i=1; i<9 ;i++) {
if (stat[i-1]==0) display.print("O ") ;
else display.print("X ") ;
display.setCursor(17.5, 50);
for(int i=9; i<17 ;i++) {
void textteller(void) {
display.setTextSize(4); // Draw 2X-scale text
display.print(F("F"));
display.println(teller);
textdecoder();
textadres();
textstatus();
// textteller();
// dps.setLocoFunc(dccadres, 1, teller);
// dps.update();
teller++ ;
delay(40000);
Hello,
I'm doing trail and error and found that functions who calls INTERRUPS are causing the problems.
In the libary DCC_Decoder.h the OLED with is getting his information trough I2C will not work when I call
DCC.SetupDecoder( 0x00, 0x00, DCC_INTERRUPT )
With the Libary DCCPacket.h it is the function DCCPacketScheduler dps;
The function are called by INTERRUPT.
Is there a solution that I2C works with an INTERRUPT handler?
