Hello Forum,
I have a problem with conflicting libraries. Anyone who knows how I can overcome this.
I have two interrupts; one to wake the ATMEGA328 and the other to retrieve data from a sensor register. I want to use pin 9 for interrupt. I get below error message when I run the code.
libraries/SoftwareSerial/SoftwareSerial.cpp.o (symbol from plugin): In function `SoftwareSerial::read()':
(.text+0x0): multiple definition of `__vector_3'
sketch/AS3935.ino.cpp.o (symbol from plugin):(.text+0x0): first defined here
(.text+0x0): multiple definition of `__vector_5'
(.text+0x0): multiple definition of `__vector_4'
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board Arduino/Genuino Uno.
Here is the code I am using.
#include "PinChangeInt.h"
#include <SPI.h>
#include "AS3935n.h"
#include <avr/sleep.h>
#include<SoftwareSerial.h>
//#include "<PinChangeInt.h>"
SoftwareSerial mySerial(8, 7); //RX, TX
String inputString = "";
bool stringComplete = false;
char time1[30];
unsigned long beit; //Stores bytes from AS3935 registers
unsigned long strokeEnergy; //Stores stroke energy from AS3935 registers
#define ARDUINOPIN 9 // Maps to ATmega328 pin15, connected to IRQ Thunder click
void printAS3935Registers();
// Function that provides SPI transfer and is passed to
// AS3935 to be used from within library.
byte SPItransfer(byte sendByte);
// Iterrupt handler for AS3935 irqs
// and flag variable that indicates interrupt has been triggered
volatile int AS3935IrqTriggered;
void AS3935Irq()// Used when
// 1. Controller wakes up from sleep
//2. When there is lightning strike and there is lightning strike.
//FIRST THING AFTER WAKING UP.
sleep_disable(); // first thing after waking from sleep: // disable sleep...
detachInterrupt(ARDUINOPIN); // wakeUpNow code will not be executed. WAKE UP NOW will not be executed during normal running time
AS3935IrqTriggered = true;
// First parameter - SPI transfer function, second - Arduino pin used for CS
// and finally third argument - Arduino pin used for IRQ
// Library internally polls this pin when doing calibration, so being an interrupt pin
// is not a requirement
AS3935 AS3935(SPItransfer,SS,ARDUINOPIN); // Here, ARDUINOPIN is not yet associated with an IRQ,
int count = 0;
char str[30];
// first begin, then set parameters
SPI.begin();
// NB! chip uses SPI MODE1
SPI.setDataMode(SPI_MODE1);
// NB! max SPI clock speed that chip supports is 2MHz,
// but never use 500kHz, because that will cause interference
// to lightning detection circuit
SPI.setClockDivider(SPI_CLOCK_DIV16);
// and chip is MSB first
SPI.setBitOrder(MSBFIRST);
// reset all internal register values to defaults
AS3935.reset();
// and run calibration
// if lightning detector can not tune tank circuit to required tolerance,
// calibration function will return false
if(!AS3935.calibrate())
Serial.println("Tuning out of range, check your wiring, your sensor and make sure physics laws have not changed!");
AS3935.setIndoors();
disableDisturbers()
AS3935.enableDisturbers();
//AS3935.disableDisturbers();
AS3935.setNoiseFloor(0011);
AS3935IrqTriggered = 0;
attachPinChangeInterrupt(ARDUINOPIN, AS3935Irq, RISING);
//attachInterrupt(ARDUINOPIN, AS3935Irq, RISING);
beit=256ul; //Forces beit to be unsigned long integer
// set the data rate for the SoftwareSerial port
mySerial.begin(9600);
//mySerial.println("Hello, world?");
// reserve 200 bytes for the inputString:
inputString.reserve(200);
//Serial.println(count);
Wakeloop(); // We check whether ATMEGA328 needs to be asleep or awake
if(AS3935IrqTriggered)
// reset the flag
// first step is to find out what caused interrupt
// as soon as we read interrupt cause register, irq pin goes low
int irqSource = AS3935.interruptSource();
// returned value is bitmap field, bit 0 - noise level too high, bit 2 - disturber detected, and finally bit 3 - lightning!
if (irqSource & 0b0001)
Serial.println("Noise level too high, try adjusting noise floor");
Serial.println("Entering Sleep Mode ");
sleepNow();
//return;
if (irqSource & 0b1000) //Original code to select only valid lightning events
// need to find how far that lightning stroke, function returns approximate distance in kilometers,
//ke where value 1 represents storm in detector's near victinity, and 63 - very distant, out of range stroke
// everything in between is just distance in kilometers
int strokeDistance = AS3935.lightningDistanceKm();
if (strokeDistance == 1)
Serial.println("Storm overhead, watch out!");
if (strokeDistance == 63)
Serial.println("Out of range lightning detected.");
if (strokeDistance < 63 && strokeDistance > 1)
Serial.print("Lightning detected ");
Serial.print(strokeDistance,DEC);
Serial.println(" kilometers away.");
byte strokeEnergyB0 = AS3935.registerRead(0x06, 31);
byte strokeEnergyB1 = AS3935.registerRead(0x05, 255);
byte strokeEnergyB2 = AS3935.registerRead(0x04, 255);
unsigned long strokeEnergy = beit*beit*strokeEnergyB0 + beit*strokeEnergyB1 + strokeEnergyB2;
Serial.println(strokeEnergy);
itoa(strokeDistance, str, 10); //Turn value into a character array
Serial.write(strokeDistance);
itoa(strokeEnergy, str, 10);
Serial.write(strokeEnergy);
//itoa(strokeEnergy, str, 10);
function to send data via SD12 will be here
Parameters to be sent
1. Stroke Distance
2. StrokeEnergy
3. GPS timestamp
4. Latitude and Longitude (from GPS)
count=0;
int noiseFloor = AS3935.getNoiseFloor();
int spikeRejection = AS3935.getSpikeRejection();
int watchdogThreshold = AS3935.getWatchdogThreshold();
Serial.print("Noise floor is: ");
Serial.println(noiseFloor,DEC);
Serial.print("Spike rejection is: ");
Serial.println(spikeRejection,DEC);
Serial.print("Watchdog threshold is: ");
Serial.println(watchdogThreshold,DEC);
// this is implementation of SPI transfer that gets passed to AS3935
// you can (hopefully) wrap any SPI implementation in this
return SPI.transfer(sendByte);
void sleepNow()
sleep_enable();
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_mode();
void Wakeloop()
count++;
if (count >= 100000){
Serial.println("Timer: Entering Sleep mode");
delay(100);
sleepNow();
count = 0;
I also attached the libraries.
AS3935.ino (14 KB)
PinChangeInt.h (21.9 KB)
AS3935n.cpp (4.88 KB)
AS3935n.h (2.47 KB)
