Dopo alcune prove ho capito che la libreria che dava fastidio era <EthernetUdp.h> quindi siccome la libreria <Time.h> ha anche i metodi per recuperare l'ora da un ntp server ho provato ad usare quella, ma con carsi risultati.
Adesso sono bloccato in questa situazione:
questo sketch da degli errori di compilazione
* Time_NTP.pde
* Example showing time sync to NTP time source
* This sketch uses the Ethenet library with the user contributed UdpBytewise extension
#include <Time.h>
#include <Ethernet.h>
#include <UdpBytewise.h> // UDP library from: bjoern@cs.stanford.edu 12/30/2008
#if UDP_TX_PACKET_MAX_SIZE <64 || UDP_RX_PACKET_MAX_SIZE < 64
#error : UDP packet size to small - modify UdpBytewise.h to set buffers to 64 bytes
#endif
* You may need to modify the UdpBytewise.h library to allow enough space in the buffers for the NTP packets.
* Open up UdpBytewse.h and set the following buffers to 64 bytes:
* #define UDP_TX_PACKET_MAX_SIZE 64
* #define UDP_RX_PACKET_MAX_SIZE 64
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 1, 44 }; // set the IP address to an unused address on your network
byte SNTP_server_IP[] = { 192, 43, 244, 18}; // time.nist.gov
//byte SNTP_server_IP[] = { 130,149,17,21}; // ntps1-0.cs.tu-berlin.de
//byte SNTP_server_IP[] = { 192,53,103,108}; // ptbtime1.ptb.de
time_t prevDisplay = 0; // when the digital clock was displayed
const long timeZoneOffset = 0L; // set this to the offset in seconds to your local time;
Ethernet.begin(mac,ip);
Serial.println("waiting for sync");
setSyncProvider(getNtpTime);
while(timeStatus()== timeNotSet)
; // wait until the time is set by the sync provider
if( now() != prevDisplay) //update the display only if the time has changed
prevDisplay = now();
digitalClockDisplay();
void digitalClockDisplay(){
// digital clock display of the time
Serial.print(hour());
printDigits(minute());
printDigits(second());
Serial.print(" ");
Serial.print(day());
Serial.print(" ");
Serial.print(month());
Serial.print(" ");
Serial.print(year());
void printDigits(int digits){
// utility function for digital clock display: prints preceding colon and leading 0
Serial.print(":");
if(digits < 10)
Serial.print('0');
Serial.print(digits);
/*-------- NTP code ----------*/
unsigned long getNtpTime()
sendNTPpacket(SNTP_server_IP);
if ( UdpBytewise.available() ) {
for(int i=0; i < 40; i++)
UdpBytewise.read(); // ignore every field except the time
const unsigned long seventy_years = 2208988800UL + timeZoneOffset;
return getUlong() - seventy_years;
return 0; // return 0 if unable to get the time
unsigned long sendNTPpacket(byte *address)
UdpBytewise.begin(123);
UdpBytewise.beginPacket(address, 123);
UdpBytewise.write(B11100011); // LI, Version, Mode
UdpBytewise.write(0); // Stratum
UdpBytewise.write(6); // Polling Interval
UdpBytewise.write(0xEC); // Peer Clock Precision
write_n(0, 8); // Root Delay & Root Dispersion
UdpBytewise.write(49);
UdpBytewise.write(0x4E);
UdpBytewise.write(52);
write_n(0, 32); //Reference and time stamps
UdpBytewise.endPacket();
unsigned long getUlong()
unsigned long ulong = (unsigned long)UdpBytewise.read() << 24;
ulong |= (unsigned long)UdpBytewise.read() << 16;
ulong |= (unsigned long)UdpBytewise.read() << 8;
ulong |= (unsigned long)UdpBytewise.read();
return ulong;
void write_n(int what, int how_many)
for( int i = 0; i < how_many; i++ )
UdpBytewise.write(what);
Errori:
/opt/arduino-1.0.5/libraries/Ethernet/UdpString.cpp:33:19: error: types.h: File o directory non esistente
/opt/arduino-1.0.5/libraries/Ethernet/UdpString.cpp: In member function ‘void UdpStringClass::begin(uint16_t)’:
/opt/arduino-1.0.5/libraries/Ethernet/UdpString.cpp:45: error: ‘Sn_MR_UDP’ was not declared in this scope
/opt/arduino-1.0.5/libraries/Ethernet/UdpString.cpp: In member function ‘int UdpStringClass::available()’:
/opt/arduino-1.0.5/libraries/Ethernet/UdpString.cpp:50: error: ‘getSn_RX_RSR’ was not declared in this scope
/opt/arduino-1.0.5/libraries/Ethernet/UdpString.cpp: In member function ‘int UdpStringClass::sendPacket(String, byte*, unsigned int)’:
/opt/arduino-1.0.5/libraries/Ethernet/UdpString.cpp:56: error: ‘class String’ has no member named ‘cstr’
/opt/arduino-1.0.5/libraries/Ethernet/UdpString.cpp: In member function ‘int UdpStringClass::sendPacket(String, int, byte*, unsigned int)’:
/opt/arduino-1.0.5/libraries/Ethernet/UdpString.cpp:60: error: ‘class String’ has no member named ‘cstr’
/opt/arduino-1.0.5/hardware/arduino/cores/arduino/WString.h: In member function ‘int UdpStringClass::readPacket(String&, byte*, unsigned int*)’:
/opt/arduino-1.0.5/hardware/arduino/cores/arduino/WString.h:176: error: ‘unsigned int String::capacity’ is protected
/opt/arduino-1.0.5/libraries/Ethernet/UdpString.cpp:73: error: within this context
/opt/arduino-1.0.5/libraries/Ethernet/UdpString.cpp:73: error: ‘str->String::capacity’ cannot be used as a function
/opt/arduino-1.0.5/libraries/Ethernet/UdpString.cpp:79: error: ‘class String’ has no member named ‘cstr’
/opt/arduino-1.0.5/libraries/Ethernet/UdpString.cpp:79: error: ‘str->String::capacity’ cannot be used as a function
/opt/arduino-1.0.5/libraries/Ethernet/UdpString.cpp:79: error: within this context
Altrimenti avete conoscenza di qualche libreria per fare uno schedule, la libreria <TimeAlarms.h> mi sembrava buona ma non compila una mazza già ho dovuto correggere degli errori di compilazione e il risultato sono altri errori. Forse se rinuncio ad aggiornale l'ora via ntp forse posso usarla, ne frattempo se avete dei suggerimenti li accetto volentieri.
Grazie
P.s.
uso arduino uno, con ide arduino-1.0.5
