Sto sperimentando uno scoreboard per padel su uno scketch trovato online. Nell'originale il punteggio viene aggiornato tramite un telecomando a 433 mhz e visualizzato su display LCD e tutto funziona egregiamente. Vorrei sperimentare la visualizzazione su un LED RGB Matrix 63x32. Purtroppo non appena inserisco il paramentro "matrix.begin();" nel setup void, immediatamente viene bloccato il ricevitore a 433mhz. C'è conflitto tra le due librerie? come potrei ovviare al problema? grazie
/*More Tutorial Visit our
Youtube Channel: https://bit.ly/2DyLaeE
FaceBook Group: https://bit.ly/2ZCrK1S
Blog Link: https://automationbd1.blogspot.com
#include <Adafruit_GFX.h>
#include <RGBmatrixPanel.h> // Hardware-specific library
#include <FreeMonoBold24pt7b.h>
#include <kongtext4pt7b.h>
LiquidCrystal_I2C lcd(0x27,20,4);
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
#define CLK 11 // USE THIS ON ARDUINO MEGA
#define OE 9
#define LAT 10
#define A A0
#define B A1
#define C A2
#define D A3
// Last parameter = 'true' enables double-buffering, for flicker-free,
// buttery smooth animation. Note that NOTHING WILL SHOW ON THE DISPLAY
// until the first call to swapBuffers(). This is normal.
//RGBmatrixPanel matrix(A, B, C, CLK, LAT, OE, true);
RGBmatrixPanel matrix(A, B, C, D, CLK, LAT, OE, true, 64);
uint16_t myRED = matrix.Color333(7,0,0);
uint16_t myGREEN = matrix.Color333(0,7,0);
uint16_t myBLUE = matrix.Color333(0,0,7);
uint16_t myWHITE = matrix.Color333(7, 7,7);
uint16_t myYELLOW = matrix.Color333(7,7,0);
uint16_t myCYAN = matrix.Color333(0,7,7);
uint16_t myMAGENTA = matrix.Color333(7,0,7);
uint16_t myShadow = matrix.Color333(4,0,7);
uint16_t myROSE = matrix.Color333(7,0,4);
uint16_t myBLACK = matrix.Color333(0,0,0);
uint16_t myCOLORS[10] = {myRED, myGREEN, myWHITE, myMAGENTA, myBLUE, myYELLOW, myCYAN, myShadow, myROSE, myBLACK};
const int reset =9 ;
int buttonPushCounter = 0; // counter for the number of button presses player 1
int buttonPushCounterPlayer2 = 0; // counter for the number of button presses player 2
int up_buttonState = 0; // current state of the up button player 1
int up_buttonState2 = 0; // current state of the up button player 2
int up_lastButtonState = 0; //previous state of the button Player 1
int up_lastButtonState2 = 0; // previous state of the up button Player 2
int padelValue = 0; //points player 1
int padelValuePlayer2 = 0; //points player 2
int padelGamePlayer1 = 0; // games player 1
int padelGamePlayer2 = 0; //games Player 2
int padelSetPlayer1 = 0; //sets Player 1
int padelSetPlayer2 = 0; //sets player 2
boolean upPlayer1 = LOW;
boolean upPlayer2 = LOW;
matrix.begin();
matrix.setTextWrap(false); // Allow text to run off right edge
matrix.setTextSize(1);
lcd.init(); // initialize the lcd
// Print a message to the LCD.
lcd.backlight();
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print("Padel Score:");
lcd.setCursor(2, 1);
lcd.print(buttonPushCounter);
mySwitch.enableReceive(0); // Receiver on interrupt 0 => that is pin #2
if (mySwitch.available()) //433Mhz recognition code
unsigned long int num = mySwitch.getReceivedValue();
Serial.print(num);
switch(num)
case 5592332:
upPlayer1 = HIGH;
mySwitch.disableReceive();
case 5592512:
upPlayer2 = HIGH;
unsigned long time_now = millis();
int ck = 500;
while (millis() < time_now + ck)
mySwitch.resetAvailable();
player1Points();
player2Points();
player1Set();
player2Set();
player1Games();
player2Games();
if ( upPlayer1 || upPlayer2)
lcd.print(" ");
lcd.print(padelSetPlayer1);
lcd.print(padelGamePlayer1);
if(padelValue==60){
lcd.print( "AD");} else
lcd.print(padelValue);}
lcd.print ("-");
if(padelValuePlayer2==60){
lcd.print(padelValuePlayer2);}
lcd.print(padelGamePlayer2);
lcd.print(padelSetPlayer2);
Serial.print(buttonPushCounter);
Serial.print(buttonPushCounterPlayer2);
upPlayer1 = LOW;
upPlayer2 = LOW;
void player1Points()
up_buttonState = upPlayer1;
if (up_buttonState != up_lastButtonState) // compare the buttonState to its previous state
if (up_buttonState == LOW) // if the state has changed, increment the counter
upPlayer1 = HIGH;
buttonPushCounter++;
switch (buttonPushCounter) {
case 1:
padelValue = 15;
Serial.println(padelValue);
case 2:
padelValue = 30;
case 3:
padelValue = 40;
case 4:
if(padelValuePlayer2 == 40 && padelValue == 40){
padelValue = 60;
Serial.println("AD");
} else if(padelValuePlayer2==60 && padelValue==40){
padelValue=40;
padelValuePlayer2=40;
buttonPushCounter=3;
buttonPushCounterPlayer2=3;
break;}
else{
padelValue = 0;
padelGamePlayer1++;
buttonPushCounterPlayer2=0;
buttonPushCounter=0;
case 5:
if (padelValue==40){
else if (padelValuePlayer2==60 && padelValue==40){
padelValue = 40;
padelValuePlayer2 = 40;
buttonPushCounter = 4;}
else{
padelValue = 0;
padelGamePlayer1++;
default:
// if nothing else matches, do the default
// default is optional
Serial.println("on");
Serial.print("number of button pushes: ");
//Serial.println(buttonPushCounter);
else {
Serial.println("off"); // if the current state is LOW then the button went from on to off:
delay(50); // Delay a little bit to avoid bouncing
up_lastButtonState = up_buttonState; // save the current state as the last state, for next time through the loop
void player2Points()
//up_buttonState2 = digitalRead(upPlayer2);
up_buttonState2 = upPlayer2;
if (up_buttonState2 != up_lastButtonState2) // compare the buttonState to its previous state
if (up_buttonState2 == HIGH) // if the state has changed, increment the counter
upPlayer2 = HIGH;
//bPress = true; // if the current state is HIGH then the button went from off to on:
buttonPushCounterPlayer2++;
switch (buttonPushCounterPlayer2) {
case 1:
padelValuePlayer2 = 15;
Serial.println(padelValuePlayer2);
case 2:
padelValuePlayer2 = 30;
case 3:
case 4:
padelValuePlayer2 = 60;
Serial.println("AD");}
else if(padelValuePlayer2==40 && padelValue==60){
padelValue=40;
break;}
else{
padelValue = 0;
padelGamePlayer2++;
Serial.println(padelValuePlayer2);}
case 5:
if(padelValuePlayer2 == 40){
else if(padelValue==60 && padelValuePlayer2==40){
padelValue = 40;
buttonPushCounterPlayer2 = 4;
else{padelValuePlayer2 = 0;
padelValue = 0;
padelGamePlayer2++;
default:
else {
up_lastButtonState2 = up_buttonState2; // save the current state as the last state, for next time through the loop
void player1Set(){
if (padelGamePlayer1 == 6 && padelGamePlayer2 <= 4){
padelSetPlayer1++;
padelGamePlayer1=0;
padelGamePlayer2=0;
else if (padelGamePlayer1 == 7 && padelGamePlayer2 <= 5){
padelSetPlayer1++;
padelGamePlayer1=0;
padelGamePlayer2=0;
void player2Set(){
if (padelGamePlayer2 == 6 && padelGamePlayer1 <= 4){
padelSetPlayer2++;
padelGamePlayer1=0;
padelGamePlayer2=0;
else if (padelGamePlayer2 == 7 && padelGamePlayer1 <= 5){
padelSetPlayer2++;
padelGamePlayer1=0;
padelGamePlayer2=0;
void player1Games(){
if(padelSetPlayer1 == 2){
padelValue = 0;
padelValuePlayer2=0;
lcd.clear();
lcd.println("Team 1 wins!");
lcd.clear();
void player2Games(){
if(padelSetPlayer2 == 2){
padelValue = 0;
lcd.clear();
lcd.println("Team 2 wins!");
lcd.clear();
