Confused about accessing accelerometer sensor values in loop()
SO I have an ESP32 and BLA423 sensor. I can run this simple code in the loop and continuously access the sensor value in and display it in the serial terminal.
int a =0;
        sensor->getAccel(acc);
        if( a<5000 && sensor->getAccel(acc) == true)
              snprintf(report, sizeof(report),"%d,%d,%d",acc.x, acc.y, acc.z);
              Serial.println(report);
              //SerialBT.println(report);
              a++;
But I want to start displaying the accelerometer value when I send "Start" from serial and stop displaying when I send "Stop".
However, if I create something like this in the loop function
if (SerialBT.available())
    char incomingChar = SerialBT.read();
    if (incomingChar == '1')
              a++;
I need to enter the Start every loop.
Also if I create some function
void loopThis()
  int a =0;
  bool y = true;
        for (int a = 0; a <100; a++)
              a++;
              //delay(1000);
          //Serial.println(a);
and run this function in loop()
it will only display a single value in a loop.
TLDR: I want to start displaying the accelerometer value when I send "Start" from the Serial Monitor and keep on displaying until I send "Stop" to the ESP32 from the Serial Monitor.
when you read start or stop you set/reset a boolean which is used to read the sensor, e.g.
  static bool readSensor=false;
  char ch;
  if(Serial.available())
     if((ch=Serial.read())=='1')  // start reading sensor?
        readSensor=true;
     if(ch=='2')                  // stop reading?
        readSensor=false;
   if(readSensor) {
      Serial.println("readsensor");
on entering 1 readsensor is displayed once per second
enter 2 to stop it
etc etc
Cheers. You saved my ass. It works. And I understood where I was confused. :slight_smile: Thanks
