Confused about bootloaders
Can anyone help clear my confusion as regards the need for a bootloader when using the ISP connector/option?
I had some ATmega8A chips lying about and decided to build a simple circuit and try and use the Arduino core+IDE to program them.
(see diagram below).
Because I’m using the ISP connections (MISO, MOSI, CLK and RESET) via my Atmel AVR ISP MKII for direct programing, do I still need a bootloader?
I would think not, but can the Arduino IDE program boards without adding a bootloader or must it be included always?
I found an entry in boards.txt (for the Arduino NG) that also uses the ATmega8 but it specifies a bootloader.
What changes (if any), are required to support my new board?
Is it a case of simply deleting the lines that make reference to a bootloader, and if so, what about the fuse setting for the AVR for example ose that set external xtal clock and no code locking?
The only mention of fuses that I can see are on the same lines as the bootloader entries.
The Arduino NG entry below:
atmega8.name=Arduino NG or older w/ ATmega8
atmega8.upload.protocol=arduino
atmega8.upload.maximum_size=7168
atmega8.upload.speed=19200
atmega8.bootloader.low_fuses=0xdf
atmega8.bootloader.high_fuses=0xca
atmega8.bootloader.path=atmega8
atmega8.bootloader.file=ATmegaBOOT-prod-firmware-2009-11-07.hex
atmega8.bootloader.unlock_bits=0x3F
atmega8.bootloader.lock_bits=0x0F
atmega8.build.mcu=atmega8
atmega8.build.f_cpu=16000000L
atmega8.build.core=arduino
atmega8.build.variant=standard
The circuit diagram of my ATmega8A based board:
Any input greatly appreciated.
The ISP connector is used to Install the bootloader. The AVR programmer asserts the Reset line and takes over control of the part.
If you select File:Upload Using Programmer, the sketch is loaded without the bootloader and starts immediately after a Reset.
Thank you very much CrossRoads, it worked perfectly.
Glad to help.
