I have the sketch below sending a message a bit over every 2 minutes to try and get a downlink.
This device is registered on TTNv3. The uplinks show up in the TTNv3 console.
If I schedule a confirmed downlink, the console says the downlink is sent after the next uplink, and never sent again. Which implies the TTNv3 server got a confirmation of the downlink.
But I never see the downlink data in the serial console.
TTNv3 uses a 5 second rx1 delay. I think this means the rx1 window opens 5 seconds after the uplink is done and lasts for 1 second. Then a second later rx2 opens for a second.
The code below is constantly calling model.available() - is that right?
Where is rx1 and rx2 handled - in the modem firmware before endPacket() returns or would I expect the downlink data to arrive ~5 seconds after the endPacket call returns?
I think downlinks in general are working - they are required for the join and for other control purposes.
I have been able to get downlinks from LMIC on a Feather.
But I can't figure out how I'm supposed to get the application level ones using the MKRWAN library and an MKR1300 board.
I upgraded the firmware to 1.2.3 today, and the library & toolchain is up to date.
Regards, David.
LoRaModem modem;
String appEui = "0000000000000000";
String appKey = "...";
unsigned long now;
unsigned long nextPacketTime;
while (!Serial);
if (!modem.begin(AS923)) {
Serial.println("Failed to start module");
while (1) {}
Serial.print("LoRaWAN module firmware version: ");
Serial.println(modem.version());
Serial.print("Device EUI is: ");
Serial.println(modem.deviceEUI());
boolean connected = modem.joinOTAA(appEui, appKey);
if (!connected) {
Serial.println("Could not join.");
while (1) {}
Serial.println("Join ok.");
modem.setPort(3);
nextPacketTime = millis() + 2500;
uint32_t counter = 0;
uint8_t data[4] = { 0xFE, 0xFE, 0xFE, 0xFE };
int rcv[64];
int rc;
now = millis();
if (now > nextPacketTime) {
// Send the counter in big-endian format.
uint8_t *ptr = (uint8_t *)&counter;
data[0] = ptr[3];
data[1] = ptr[2];
data[2] = ptr[1];
data[3] = ptr[0];
modem.beginPacket();
rc = modem.write(data, 4);
rc = modem.endPacket();
Serial.print("endPacket returned "); Serial.println(rc);
nextPacketTime = now + (1000 * 60 * 2) + 3000;
counter++;
if (!modem.available()) {
return;
int i = 0;
while (modem.available() && i < 64) {
rcv[i++] = modem.read();
Serial.print("Received: ");
for (unsigned int j = 0; j < i; j++) {
Serial.print((rcv[j] & 0xF0) >> 4, HEX);
Serial.print(rcv[j] & 0x0F, HEX);
Serial.print(" ");
