On this site:
they show code like this:
//set timer0 interrupt at 2kHz
TCCR0A = 0;// set entire TCCR0A register to 0
TCCR0B = 0;// same for TCCR0B
TCNT0 = 0;//initialize counter value to 0
// set compare match register for 2khz increments
OCR0A = 124;// = (16*10^6) / (2000*64) - 1 (must be <256)
// turn on CTC mode
TCCR0A |= (1 << WGM01);
// Set CS01 and CS00 bits for 64 prescaler
TCCR0B |= (1 << CS01) | (1 << CS00);
// enable timer compare interrupt
TIMSK0 |= (1 << OCIE0A);
When I try to use the (1 << whatever) format, I get an error that says:
"expression cannot be used as a function"
I don't understand why it works for them, but not for me.
Also, why is the shifting necessary? Is WGM01, for example, a bit position (1), or is it a bit value(2)? Seems like it would be a bit value to be of any use, in which case
TCCR0A |= WGM01
should work to set that bit.
And while I'm asking, if I set the timer prescaler to 256, should I set the compare register to 250 or 249 to get a 4ms rate? I'm guessing 250.
Sorry. I'm just completely new to this. Thanks for any help.
Edit: Ok, I found that WGM01 is a bit position, which is why it needs to be shifted. But that still leaves the question of why that format doesn't work in my sketch.
