confused beyond belief
Try to write a program that reads setup data from an SD card that is in an Arduino wireless shield on a Mega R3.
Found this code which got me mostly there, and while it reads numbers and bool statements, it wont read the text stirng.
Here is the code; many thanks to Jurgen for getting me this far !
#include <SD.h>
#include <ctype.h>
File myFile;
struct parameters {
  int interval;
  boolean co2;
  boolean temp;
  boolean rh;
  boolean lux;
  boolean valid;
  boolean heater;
  String lokaal;
} settings;
// Setting for SD-card reader
const int chipSelect = 53;
void getSettings()
 // Open the settings file for reading:
  myFile = SD.open("settings.txt", FILE_READ);
  char character;
  String description = "";
  String value = "";
  boolean valid = true;
    // read from the file until there's nothing else in it:
    while (myFile.available()) {
      character = myFile.read();
             if(character == '/') {
               // Comment - ignore this line
               while(character != '\n'){
      } else if(isalnum(character)) { // Add a character to the description
        description.concat(character);
      } else if(character =='=') { // start checking the value for possible results
      // First going to trim out all trailing white spaces
      do {
      } while(character == ' ');
        if(description == "interval") {
          value = "";
          while(character != '\n') {
            if(isdigit(character)) {
              value.concat(character);
            } else if(character != '\n') {
              // Use of invalid values
              valid = false;
          if (valid) {
            // Convert string to array of chars
            char charBuf[value.length()+1];
            value.toCharArray(charBuf,value.length()+1);
            // Convert chars to integer
            settings.interval = atoi(charBuf);
            // revert to default value for invalid entry in settings
            settings.interval = 60;
        } else if(description == "co2") {
           if (character=='1') {
             settings.co2 = true;
             settings.co2 = false;
        } else if(description == "rh") {
             settings.rh = true;
             settings.rh = false;
        } else if(description == "temp") {
             settings.temp = true;
             settings.temp = false;
        } else if(description == "lux") {
             settings.lux = true;
             settings.lux = false;
        } else if(description == "heater") {
          //Serial.println("Heater");
             settings.heater = true;
             settings.heater = false;
        } else if(description == "location") {
          //Serial.println("Location");
          value = "";
           do {
           } while(character != '\n');
           settings.lokaal = value;
           Serial.print("Location=");
        Serial.println(settings.lokaal);
        }else { // unknown parameter
        description = "";
        // Ignore this character (could be space, tab, newline, carriage return or something else)
    // close the file:
    myFile.close();
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Starting...");
  pinMode(53, OUTPUT);
  if (!SD.begin(4)) {
    Serial.println("initialization failed!");
    return;
  getSettings();
  Serial.print("Interval: ");
  Serial.println(settings.interval);
  Serial.print("CO2: ");
  if(settings.co2) { Serial.println("YES"); } else { Serial.println("NO"); }
  Serial.print("TEMP:");
  if(settings.temp) { Serial.println("YES"); } else { Serial.println("NO"); }
  Serial.print("RH: ");
  if(settings.rh) { Serial.println("YES"); } else { Serial.println("NO"); }
  Serial.print("lux: ");
  if(settings.lux) { Serial.println("YES"); } else { Serial.println("NO"); }
  Serial.print("htr: ");
  if(settings.heater) { Serial.println("YES"); } else { Serial.println("NO"); }
  Serial.print("Lokaal: ");
  Serial.println("Done");
        // nothing happens after setup
Here is the file it is trying to read;
// Any line starting with one forward slash will be considered comment.
// So the typical // will also serve as a comment.
// Measure CO2-level
co2 = 1
// Don't measure relative humidity
rh = 0
// Measure temperature
temp = 1
// Don't measure light strenght
lux = 0
// Location identifier
location = Bathroom
// Don't pre-heat module
heater = 0
// Other parameters are unknown and will be ignored
xrayvision = 1
evilcommand = 0
myname = jurgen
If is change the
to
 myFile = SD.open("settings.txt", FILE_WRITE);
I get all the digits fine, but not the "bathroom" string.
If i change it back to "READ" i get the text but not the digits.
Surely, reading a file is reading a file !
Why should "WRITE" produce results, but only some of them.
Andrew
Opening a file for write shouldn't allow reading at all.
Firstly the code is poorly indented and hard to read - suggest you move all
the parsing code into separate routines, one for reading bool, one for int, one
for string, and write very simple test code for each separately using a simpler
test files and get each working independently first - then reconstruct your
file parser in terms of those routines.
Don't open the file for write if you are going to read it, complete red-herring.
Oh yes, and liberally sprinkle your code with Serial.println() debug statements
so you can see what is really going on, remove only after testing is complete.
What happens if you encounter the end of the file before you find another carriage return. This becomes an infinite loop.
That is NOT what that statement does.
The comment describes the next line, and is obvious to the point of uselessness.
You seem opposed to using the String::toInt() function. Why?
          value = "";
           do {
There are many places where this could go wrong. You need to determine where it went wrong. Is there a typo in the file on the SD card, so that description never actually matches "location"? If not, what does the while loop actually store in value?
Ok, i found this code on the internet and thought it was a good enough place to start, but it now appears to be a poor place to start.
So pointed please so i can start from scratch.
Can i read int, bool and string in the same routine or does it have to be seperate ?
I am new to Arduino so please be gentle.
Andrew
Parsing text-style configuration files like that is not simple. A simple approach leads to a lot of bugs and undetected error handling situations. You need to be very logical and systematic in your approach , and it is not a task for any but the most gifted beginners.
I suggest that you either use Strings systematically, or don't use them at all. On the arduino, the latter is probably preferable.
Yes, you can. You are now, with one probably minor exception. But, that code would be far simpler with some function calls.
Compare
to
      character = skipComment();
Which one is clearer? Which one is likely to be easier to debug?
