confused by 'String' does not name a type message
I am trying to return a string from a function call. Ease of programming and reading were more pertinent for my application than any memory concerns (apart from leaks). In my cpp files I kept getting the compiler error string does not name a type. I have simplified the code to be one function call. This call works when it is contained within an ino file, but fails to compile when moved to a header file or cpp file.
main sketch file
#include "test.h"
  String bob = getString(); //"bob" ;
  Serial.begin( 9600 );
  Serial.println( "bob" );
bool showlight = false;
  digitalWrite( LED_BUILTIN, (showlight=!showlight?HIGH:LOW) );
  delay( 1000 );
test.h
#include <string.h>
String getString()
  return "bob";
this code produces the error, but move getString to the main ino file and it all works, why is this happening?
[u]s[/u]tring is not the same as [u]S[/u]tring.
Easiest is to include Arduino.h instead of string.h. Else you can try to include WString.h but it might require other includes.
