Confused on Serial Port for Arduino Pro Mini connecting to DFPlayer Mini
I am new to the hobby (into it for 3 weeks) and I am having so much trouble getting my Arduinos to communicate with a DFPlayer Mini.
After days of fighting I finally realized I needed to use SoftwareSerial library and switch my RX and TX to pins 10 and 11. I'm not sure why I can't use the designated RX/TX pins 0 and 1. Can someone tell me what I'm doing wrong? Do you you have to define pins 0 and 1 in the code and if so, how?
Serial connections were a pain to figure out with my Arduino Uno as well but I got that working last week. I also have Arduino Nanos arriving today. I'm looking to really understand how to get the Uart RX TX pins connected properly so I can avoid this headache in the future.
My current code is as follows:
#include "Arduino.h"
#include "DFRobotDFPlayerMini.h"
#include "ezButton.h"
#if !defined(UBRR1H)
  #include <SoftwareSerial.h>
  SoftwareSerial softSerial(10, 11); // RX, TX
#endif
#define FPSerial softSerial
//definitions
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
void printLimiSwitch();
ezButton limitSwitch(7);
  limitSwitch.setDebounceTime(50);
  FPSerial.begin(9600);
  Serial.println(F("DFRobot DFPlayer Mini Demo"));
  Serial.println(F("Initializing DFPlayer ... (May take 3~5 seconds)"));
  if (!myDFPlayer.begin(FPSerial, /*isACK = */true, /*doReset = */true)) {  //Use serial to communicate with mp3.
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
     while(true){
       delay(0); // Code to compatible with ESP8266 watch dog.
  Serial.println(F("DFPlayer Mini online."));
  myDFPlayer.play(1);
  delay(100);
  static unsigned long timer = millis();
//Serial.println(digitalRead(pauseButton));
  limitSwitch.loop(); // MUST call the loop() function first
  printLimitSwitch();
  int state = limitSwitch.getState();
  Serial.println("The limit state: " + state);
  if(state == HIGH)
    Serial.println("The limit switch: UNTOUCHED");
    Serial.println("The limit switch: TOUCHED");
  /*if (myDFPlayer.available()) {
    printDetail(myDFPlayer.readType(), myDFPlayer.read()); //Print the detail message from DFPlayer to handle different errors and states.
void printLimitSwitch(){
    if(limitSwitch.isPressed())
    Serial.println("The limit switch: UNTOUCHED -> TOUCHED");
    myDFPlayer.pause();
    delay(300);
  if(limitSwitch.isReleased())
    Serial.println("The limit switch: TOUCHED -> UNTOUCHED");
    myDFPlayer.start();
    delay(300);
void printDetail(uint8_t type, int value){
  switch (type) {
    case TimeOut:
      Serial.println(F("Time Out!"));
    case WrongStack:
      Serial.println(F("Stack Wrong!"));
    case DFPlayerCardInserted:
      Serial.println(F("Card Inserted!"));
    case DFPlayerCardRemoved:
      Serial.println(F("Card Removed!"));
    case DFPlayerCardOnline:
      Serial.println(F("Card Online!"));
    case DFPlayerUSBInserted:
      Serial.println("USB Inserted!");
    case DFPlayerUSBRemoved:
      Serial.println("USB Removed!");
    case DFPlayerPlayFinished:
      Serial.print(F("Number:"));
      Serial.print(value);
      Serial.println(F(" Play Finished!"));
    case DFPlayerError:
      Serial.print(F("DFPlayerError:"));
      switch (value) {
        case Busy:
          Serial.println(F("Card not found"));
        case Sleeping:
          Serial.println(F("Sleeping"));
        case SerialWrongStack:
          Serial.println(F("Get Wrong Stack"));
        case CheckSumNotMatch:
          Serial.println(F("Check Sum Not Match"));
        case FileIndexOut:
          Serial.println(F("File Index Out of Bound"));
        case FileMismatch:
          Serial.println(F("Cannot Find File"));
        case Advertise:
          Serial.println(F("In Advertise"));
        default:
    default:
You could use pins 0 and 1.
However those are the pins used for the program upload and all those Serial.print() functions so there is a conflict.
I was thinking that might be the problem. So if I designated a separate software serial pin for the printLn stuff AND disconnected the usb connection to my pc after uploading the software, the 0 and 1 pins would work as I expect them to?
Meaning I wouldn't have to declare them in the code, just set "Serial.begin(9600);"
and modify "if (!myDFPlayer.begin(FPSerial, /*isACK = */true, /*doReset = */true))" to use Serial instead of the FPSerial variable, right?
(Obviously I'd have to adjust all the code to call to the correct serial connection for all of the print line code.)
I dont have a DFRobotDFPlayerMini to check for you.
Might be an idea to follow the tutorial given with the library, its for a UNO but the pin numbers used should be the same.
