Confusing Error in Output
I am trying yo complete the Weather Station project and keep getting an error when compiling that doesn't seem correct.
Here it is:
c:\Users\davel\Documents\Arduino\libraries\ESP8266_Weather_Station\src\MetOfficeClient.cpp: In member function 'String MetOfficeClient::getWeatherIconName(String)':
c:\Users\davel\Documents\Arduino\libraries\ESP8266_Weather_Station\src\MetOfficeClient.cpp:463:1: error: control reaches end of non-void function [-Werror=return-type]
463 | }
There is no such code in the Weather Station Demo that I have been able to uncover. Is there a way to simply disregard this error in order to get a clean compiling function?
Please get me restarted.
Thank you,
Dave
Please post the sketch that you are trying to compile, using < CODE/ > tags when you do
I don't know if I can help. But I know that unfortunately something went wrong. If you post a message and have a question, always include the code and the error message. Paste the code by clicking on the button (as in the picture) and then paste the code. You should also do the same with the error message. This makes it much easier to help you.
Are you not seen a
file on your PC hard disk?
Which weather station project do you mean?
Help us help you.
B707,
Sorry, no I am not seeing that line of code in my sketch.
I think I may have unintentionally miss-led you. There is a following line that copy did not pick up.
Here it is:
cc1plus.exe: some warnings being treated as error
Sorry,
Dave
That is what the "Copy error messages" button is there for
it is not in your sketch, it is in the file
This is the code for the Weather Station Demo . File/Examples/Esp8266 Weather Station/WeatherStationDemo
Using board 'nodemcuv2' from platform in folder.
Here is the code:
`Use code tags to format code for the forum````
```cpp
#include <Arduino.h>
#include <ESPWiFi.h>
#include <ESPHTTPClient.h>
#include <JsonListener.h>
// time
#include <time.h>       // time() ctime()
#include <sys/time.h>   // struct timeval
#include <coredecls.h>  // settimeofday_cb()
#include "SSD1306Wire.h"
#include "OLEDDisplayUi.h"
#include "Wire.h"
#include "OpenWeatherMapCurrent.h"
#include "OpenWeatherMapForecast.h"
#include "WeatherStationFonts.h"
#include "WeatherStationImages.h"
 * Begin Settings
// WIFI
const char *WIFI_SSID = "TMobile BH-6015";
const char *WIFI_PWD = "causation.washer.yeah.shore";
#define TZ 2       // (utc+) TZ in hours
#define DST_MN 60  // use 60mn for summer time in some countries
// Setup
const int UPDATE_INTERVAL_SECS = 20 * 60;  // Update every 20 minutes
// Display Settings
const int I2C_DISPLAY_ADDRESS = 0x3c;
#if defined(ESP8266)
const int SDA_PIN = D3;
const int SDC_PIN = D4;
#else
const int SDA_PIN = 5;  //D3;
const int SDC_PIN = 4;  //D4;
#endif
// OpenWeatherMap Settings
// Sign up here to get an API key:
// https://docs.thingpulse.com/how-tos/openweathermap-key/
String OPEN_WEATHER_MAP_APP_ID = "8551c8653f07c78d6ed42e1642d796b4";
Go to https://openweathermap.org/find?q= and search for a location. Go through the
result set and select the entry closest to the actual location you want to display
data for. It'll be a URL like https://openweathermap.org/city/2657896. The number
at the end is what you assign to the constant below.
String OPEN_WEATHER_MAP_LOCATION_ID = "Winston-Salem, NC";
// Pick a language code from this list:
// Arabic - ar, Bulgarian - bg, Catalan - ca, Czech - cz, German - de, Greek - el,
// English - en, Persian (Farsi) - fa, Finnish - fi, French - fr, Galician - gl,
// Croatian - hr, Hungarian - hu, Italian - it, Japanese - ja, Korean - kr,
// Latvian - la, Lithuanian - lt, Macedonian - mk, Dutch - nl, Polish - pl,
// Portuguese - pt, Romanian - ro, Russian - ru, Swedish - se, Slovak - sk,
// Slovenian - sl, Spanish - es, Turkish - tr, Ukrainian - ua, Vietnamese - vi,
// Chinese Simplified - zh_cn, Chinese Traditional - zh_tw.
String OPEN_WEATHER_MAP_LANGUAGE = "en";
const uint8_t MAX_FORECASTS = 4;
const boolean IS_METRIC = true;
// Adjust according to your language
const String WDAY_NAMES[] = { "SUN", "MON", "TUE", "WED", "THU", "FRI", "SAT" };
const String MONTH_NAMES[] = { "JAN", "FEB", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP", "OCT", "NOV", "DEC" };
 * End Settings
// Initialize the oled display for address 0x3c
// sda-pin=14 and sdc-pin=12
SSD1306Wire display(I2C_DISPLAY_ADDRESS, SDA_PIN, SDC_PIN);
OLEDDisplayUi ui(&display);
OpenWeatherMapCurrentData currentWeather;
OpenWeatherMapCurrent currentWeatherClient;
OpenWeatherMapForecastData forecasts[MAX_FORECASTS];
OpenWeatherMapForecast forecastClient;
#define TZ_MN ((TZ)*60)
#define TZ_SEC ((TZ)*3600)
#define DST_SEC ((DST_MN)*60)
time_t now;
// flag changed in the ticker function every 10 minutes
bool readyForWeatherUpdate = false;
String lastUpdate = "--";
long timeSinceLastWUpdate = 0;
//declaring prototypes
void drawProgress(OLEDDisplay *display, int percentage, String label);
void updateData(OLEDDisplay *display);
void drawDateTime(OLEDDisplay *display, OLEDDisplayUiState *state, int16_t x, int16_t y);
void drawCurrentWeather(OLEDDisplay *display, OLEDDisplayUiState *state, int16_t x, int16_t y);
void drawForecast(OLEDDisplay *display, OLEDDisplayUiState *state, int16_t x, int16_t y);
void drawForecastDetails(OLEDDisplay *display, int x, int y, int dayIndex);
void drawHeaderOverlay(OLEDDisplay *display, OLEDDisplayUiState *state);
void setReadyForWeatherUpdate();
// Add frames
// this array keeps function pointers to all frames
// frames are the single views that slide from right to left
FrameCallback frames[] = { drawDateTime, drawCurrentWeather, drawForecast };
int numberOfFrames = 3;
OverlayCallback overlays[] = { drawHeaderOverlay };
int numberOfOverlays = 1;
  // initialize dispaly
  display.init();
  display.clear();
  display.display();
  //display.flipScreenVertically();
  display.setFont(ArialMT_Plain_10);
  display.setTextAlignment(TEXT_ALIGN_CENTER);
  display.setContrast(255);
  WiFi.begin(WIFI_SSID, WIFI_PWD);
  int counter = 0;
    Serial.print(".");
    display.clear();
    display.drawString(64, 10, "Connecting to WiFi");
    display.drawXbm(46, 30, 8, 8, counter % 3 == 0 ? activeSymbole : inactiveSymbole);
    display.drawXbm(60, 30, 8, 8, counter % 3 == 1 ? activeSymbole : inactiveSymbole);
    display.drawXbm(74, 30, 8, 8, counter % 3 == 2 ? activeSymbole : inactiveSymbole);
    display.display();
    counter++;
  // Get time from network time service
  configTime(TZ_SEC, DST_SEC, "pool.ntp.org");
  ui.setTargetFPS(30);
  ui.setActiveSymbol(activeSymbole);
  ui.setInactiveSymbol(inactiveSymbole);
  // You can change this to
  // TOP, LEFT, BOTTOM, RIGHT
  ui.setIndicatorPosition(BOTTOM);
  // Defines where the first frame is located in the bar.
  ui.setIndicatorDirection(LEFT_RIGHT);
  // You can change the transition that is used
  // SLIDE_LEFT, SLIDE_RIGHT, SLIDE_TOP, SLIDE_DOWN
  ui.setFrameAnimation(SLIDE_LEFT);
  ui.setFrames(frames, numberOfFrames);
  ui.setOverlays(overlays, numberOfOverlays);
  // Inital UI takes care of initalising the display too.
  ui.init();
  Serial.println("");
  updateData(&display);
  if (millis() - timeSinceLastWUpdate > (1000L * UPDATE_INTERVAL_SECS)) {
    timeSinceLastWUpdate = millis();
  if (readyForWeatherUpdate && ui.getUiState()->frameState == FIXED) {
  int remainingTimeBudget = ui.update();
  if (remainingTimeBudget > 0) {
    // You can do some work here
    // Don't do stuff if you are below your
    // time budget.
    delay(remainingTimeBudget);
void drawProgress(OLEDDisplay *display, int percentage, String label) {
  display->clear();
  display->setTextAlignment(TEXT_ALIGN_CENTER);
  display->setFont(ArialMT_Plain_10);
  display->drawString(64, 10, label);
  display->drawProgressBar(2, 28, 124, 10, percentage);
  display->display();
void updateData(OLEDDisplay *display) {
  drawProgress(display, 10, "Updating time...");
  drawProgress(display, 30, "Updating weather...");
  currentWeatherClient.setMetric(IS_METRIC);
  currentWeatherClient.setLanguage(OPEN_WEATHER_MAP_LANGUAGE);
  currentWeatherClient.updateCurrentById(&currentWeather, OPEN_WEATHER_MAP_APP_ID, OPEN_WEATHER_MAP_LOCATION_ID);
  drawProgress(display, 50, "Updating forecasts...");
  forecastClient.setMetric(IS_METRIC);
  forecastClient.setLanguage(OPEN_WEATHER_MAP_LANGUAGE);
  uint8_t allowedHours[] = { 12 };
  forecastClient.setAllowedHours(allowedHours, sizeof(allowedHours));
  forecastClient.updateForecastsById(forecasts, OPEN_WEATHER_MAP_APP_ID, OPEN_WEATHER_MAP_LOCATION_ID, MAX_FORECASTS);
  drawProgress(display, 100, "Done...");
void drawDateTime(OLEDDisplay *display, OLEDDisplayUiState *state, int16_t x, int16_t y) {
  now = time(nullptr);
  struct tm *timeInfo;
  timeInfo = localtime(&now);
  char buff[16];
  String date = WDAY_NAMES[timeInfo->tm_wday];
  sprintf_P(buff, PSTR("%s, %02d/%02d/%04d"), WDAY_NAMES[timeInfo->tm_wday].c_str(), timeInfo->tm_mday, timeInfo->tm_mon + 1, timeInfo->tm_year + 1900);
  display->drawString(64 + x, 5 + y, String(buff));
  display->setFont(ArialMT_Plain_24);
  sprintf_P(buff, PSTR("%02d:%02d:%02d"), timeInfo->tm_hour, timeInfo->tm_min, timeInfo->tm_sec);
  display->drawString(64 + x, 15 + y, String(buff));
  display->setTextAlignment(TEXT_ALIGN_LEFT);
void drawCurrentWeather(OLEDDisplay *display, OLEDDisplayUiState *state, int16_t x, int16_t y) {
  display->drawString(64 + x, 38 + y, currentWeather.description);
  String temp = String(currentWeather.temp, 1) + (IS_METRIC ? "°C" : "°F");
  display->drawString(60 + x, 5 + y, temp);
  display->setFont(Meteocons_Plain_36);
  display->drawString(32 + x, 0 + y, currentWeather.iconMeteoCon);
void drawForecast(OLEDDisplay *display, OLEDDisplayUiState *state, int16_t x, int16_t y) {
  drawForecastDetails(display, x, y, 0);
  drawForecastDetails(display, x + 44, y, 1);
  drawForecastDetails(display, x + 88, y, 2);
void drawForecastDetails(OLEDDisplay *display, int x, int y, int dayIndex) {
  time_t observationTimestamp = forecasts[dayIndex].observationTime;
  timeInfo = localtime(&observationTimestamp);
  display->drawString(x + 20, y, WDAY_NAMES[timeInfo->tm_wday]);
  display->setFont(Meteocons_Plain_21);
  display->drawString(x + 20, y + 12, forecasts[dayIndex].iconMeteoCon);
  String temp = String(forecasts[dayIndex].temp, 0) + (IS_METRIC ? "°C" : "°F");
  display->drawString(x + 20, y + 34, temp);
void drawHeaderOverlay(OLEDDisplay *display, OLEDDisplayUiState *state) {
  char buff[14];
  sprintf_P(buff, PSTR("%02d:%02d"), timeInfo->tm_hour, timeInfo->tm_min);
  display->setColor(WHITE);
  display->drawString(0, 54, String(buff));
  display->setTextAlignment(TEXT_ALIGN_RIGHT);
  display->drawString(128, 54, temp);
  display->drawHorizontalLine(0, 52, 128);
void setReadyForWeatherUpdate() {
  Serial.println("Setting readyForUpdate to true");
  readyForWeatherUpdate = true;
Bob,
I sent the text with some explanation but the editor would not attach the error message. Post was over the maximum so I am adding it here. I am still working on my linking skills.
Error message: Use code tags to format code for the forum
Using board 'nodemcuv2' from platform in folder: C:\Users\davel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
Using core 'esp8266' from platform in folder: C:\Users\davel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/mkbuildoptglobals.py" "C:\\Users\\davel\\Desktop\\Aduino Files\\Arduino IDE\\resources\\app\\node_modules\\arduino-ide-extension\\build" 10607 "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498" "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "C:\\Users\\davel\\Documents\\Arduino\\WeatherStationDemo/WeatherStationDemo.ino.globals.h" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266/CommonHFile.h"
default_encoding:       cp1252
Assume aggressive 'core.a' caching enabled.
Note: optional global include file 'C:\Users\davel\Documents\Arduino\WeatherStationDemo\WeatherStationDemo.ino.globals.h' does not exist.
  Read more at https://arduino-esp8266.readthedocs.io/en/latest/faq/a06-global-build-options.html
Detecting libraries used...
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\sketch\\WeatherStationDemo.ino.cpp" -o nul
Alternatives for ESPWiFi.h: [ESP8266 Weather Station@2.0.1]
ResolveLibrary(ESPWiFi.h)
  -> candidates: [ESP8266 Weather Station@2.0.1]
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\sketch\\WeatherStationDemo.ino.cpp" -o nul
Alternatives for ESP8266WiFi.h: [ESP8266WiFi@1.0]
ResolveLibrary(ESP8266WiFi.h)
  -> candidates: [ESP8266WiFi@1.0]
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\sketch\\WeatherStationDemo.ino.cpp" -o nul
Alternatives for ESP8266HTTPClient.h: [ESP8266HTTPClient@1.2]
ResolveLibrary(ESP8266HTTPClient.h)
  -> candidates: [ESP8266HTTPClient@1.2]
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\sketch\\WeatherStationDemo.ino.cpp" -o nul
Alternatives for JsonListener.h: [Json Streaming Parser@1.0.5]
ResolveLibrary(JsonListener.h)
  -> candidates: [Json Streaming Parser@1.0.5]
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\sketch\\WeatherStationDemo.ino.cpp" -o nul
Alternatives for SSD1306Wire.h: [ESP8266 and ESP32 OLED driver for SSD1306 displays@4.4.0]
ResolveLibrary(SSD1306Wire.h)
  -> candidates: [ESP8266 and ESP32 OLED driver for SSD1306 displays@4.4.0]
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\sketch\\WeatherStationDemo.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\sketch\\WeatherStationDemo.ino.cpp" -o nul
Using cached library dependencies for file: c:\Users\davel\Documents\Arduino\libraries\ESP8266_Weather_Station\src\AerisForecasts.cpp
Using cached library dependencies for file: c:\Users\davel\Documents\Arduino\libraries\ESP8266_Weather_Station\src\AerisObservations.cpp
Using cached library dependencies for file: c:\Users\davel\Documents\Arduino\libraries\ESP8266_Weather_Station\src\AerisSunMoon.cpp
Using cached library dependencies for file: c:\Users\davel\Documents\Arduino\libraries\ESP8266_Weather_Station\src\Astronomy.cpp
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src\\MetOfficeClient.cpp" -o nul
Using cached library dependencies for file: c:\Users\davel\Documents\Arduino\libraries\ESP8266_Weather_Station\src\NTPClient.cpp
Using cached library dependencies for file: c:\Users\davel\Documents\Arduino\libraries\ESP8266_Weather_Station\src\OpenWeatherMapCurrent.cpp
Using cached library dependencies for file: c:\Users\davel\Documents\Arduino\libraries\ESP8266_Weather_Station\src\OpenWeatherMapForecast.cpp
Using cached library dependencies for file: c:\Users\davel\Documents\Arduino\libraries\ESP8266_Weather_Station\src\SunMoonCalc.cpp
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src\\ThingspeakClient.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src\\TimeClient.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src\\WorldClockClient.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\BearSSLHelpers.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\CertStoreBearSSL.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFi.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiAP.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiGeneric.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiGratuitous.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiMulti.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiSTA-WPS.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiSTA.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\ESP8266WiFiScan.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\WiFiClient.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\WiFiClientSecureBearSSL.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\WiFiServer.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\WiFiServerSecureBearSSL.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\WiFiUdp.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src\\enable_wifi_at_boot_time.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src\\ESP8266HTTPClient.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser\\JsonListener.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser\\JsonStreamingParser.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src\\OLEDDisplay.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src\\OLEDDisplayUi.cpp" -o nul
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire\\Wire.cpp" -o nul
Generating function prototypes...
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/none-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\sketch\\WeatherStationDemo.ino.cpp" -o "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\builtin\\tools\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\python3\\3.7.2-post1/python3" -I "C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/signing.py" --mode header --publickey "C:\\Users\\davel\\Documents\\Arduino\\WeatherStationDemo/public.key" --out "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/Updater_Signing.h"
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/default-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\sketch\\WeatherStationDemo.ino.cpp" -o "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\sketch\\WeatherStationDemo.ino.cpp.o"
Compiling libraries...
Compiling library "ESP8266 Weather Station"
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/default-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src\\AerisForecasts.cpp" -o "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\libraries\\ESP8266_Weather_Station\\AerisForecasts.cpp.o"
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/default-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src\\Astronomy.cpp" -o "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\libraries\\ESP8266_Weather_Station\\Astronomy.cpp.o"
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/default-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src\\AerisSunMoon.cpp" -o "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\libraries\\ESP8266_Weather_Station\\AerisSunMoon.cpp.o"
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/default-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src\\AerisObservations.cpp" -o "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\libraries\\ESP8266_Weather_Station\\AerisObservations.cpp.o"
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/default-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src\\MetOfficeClient.cpp" -o "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\libraries\\ESP8266_Weather_Station\\MetOfficeClient.cpp.o"
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/default-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src\\NTPClient.cpp" -o "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\libraries\\ESP8266_Weather_Station\\NTPClient.cpp.o"
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/default-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src\\OpenWeatherMapCurrent.cpp" -o "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\libraries\\ESP8266_Weather_Station\\OpenWeatherMapCurrent.cpp.o"
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/default-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src\\OpenWeatherMapForecast.cpp" -o "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\libraries\\ESP8266_Weather_Station\\OpenWeatherMapForecast.cpp.o"
c:\Users\davel\Documents\Arduino\libraries\ESP8266_Weather_Station\src\MetOfficeClient.cpp: In member function 'String MetOfficeClient::getWeatherIconName(String)':
c:\Users\davel\Documents\Arduino\libraries\ESP8266_Weather_Station\src\MetOfficeClient.cpp:463:1: error: control reaches end of non-void function [-Werror=return-type]
  463 | }
cc1plus.exe: some warnings being treated as errors
"C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\tools\\xtensa-lx106-elf-gcc\\3.1.0-gcc10.3-e5f9fec/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE -DESP8266 "@C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core/build.opt" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/lwip2/include" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/sdk/libc/xtensa-lx106-elf/include" "-IC:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498/core" -c "@C:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2/tools/warnings/default-cppflags" -Os -g -free -fipa-pta -Werror=return-type -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -MMD -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10607 -DARDUINO_ESP8266_NODEMCU_ESP12E -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=\"ESP8266_NODEMCU_ESP12E\"" "-DARDUINO_BOARD_ID=\"nodemcuv2\"" -DLED_BUILTIN=2 -DFLASHMODE_DIO "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\cores\\esp8266" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\variants\\nodemcu" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266WiFi\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\ESP8266HTTPClient\\src" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\Json_Streaming_Parser" "-Ic:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays\\src" "-IC:\\Users\\davel\\AppData\\Local\\Arduino15\\packages\\esp8266\\hardware\\esp8266\\3.1.2\\libraries\\Wire" "c:\\Users\\davel\\Documents\\Arduino\\libraries\\ESP8266_Weather_Station\\src\\SunMoonCalc.cpp" -o "C:\\Users\\davel\\AppData\\Local\\Temp\\arduino\\sketches\\13783D2438DA227F31E79A269B1A8498\\libraries\\ESP8266_Weather_Station\\SunMoonCalc.cpp.o"
Using library ESP8266 Weather Station at version 2.0.1 in folder: C:\Users\davel\Documents\Arduino\libraries\ESP8266_Weather_Station
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\davel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266WiFi
Using library ESP8266HTTPClient at version 1.2 in folder: C:\Users\davel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\ESP8266HTTPClient
Using library Json Streaming Parser at version 1.0.5 in folder: C:\Users\davel\Documents\Arduino\libraries\Json_Streaming_Parser
Using library ESP8266 and ESP32 OLED driver for SSD1306 displays at version 4.4.0 in folder: C:\Users\davel\Documents\Arduino\libraries\ESP8266_and_ESP32_OLED_driver_for_SSD1306_displays
Using library Wire at version 1.0 in folder: C:\Users\davel\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.1.2\libraries\Wire
exit status 1
Compilation error: exit status 1
