Confusion as to which header to use for SPI on Due - ICSP or SPI
I am attempting to hook up a peripheral that uses SPI for an interface. While reading the SPI library, it says to use the ICSP header for SPI. However, there is a specific header on the Due labelled SPI. Which one should I be using?
Thanks for your help!
On the Due use the header marked SPI for SPI ;) I think the ICSP is for the 16U2 only, could be wrong.
Thanks! :smiley:
I figured as much - but I was not finding supporting encouragement from the SPI library API. I guess that’s what we get for living on the bleeding (Due) edge :slight_smile:
attention to not exceed 3.3V at the pins of the Due (SPI-2 is connected to +5V). A valuable source in such cases is: http://arduino.cc/en/uploads/Main/arduino-Due-schematic.pdf where you can solve the puzzle - what is connected to what. I think the confusion SPI/ICSP is caused by the common ISP-library documentation with was issued for the standard Arduino boards - there is not yet a hint for the different labels at the Due.
I wrote up some info on using hardware SPI on Due http://21stdigitalhome.blogspot.com/2013/02/arduino-due-hardware-spi.html to include pins and other info to supplement the extended SPI calls at http://arduino.cc/en/Reference/DueExtendedSPI
Can you please correct the Documentation here: https://www.arduino.cc/en/Reference/SPI and change the word ICSP to SPI at DUE?
