What exactly is arduino programming language? Is it only 'C' or only'C++' or mix of both 'C'and 'C++' ???
Yes. C++ is backwards compatible with C, so you can mix C and C++ features in your code as you like.
What makes Arduino language different to standard C/C++ is that a small number of standard functions & features have been removed because they consume too many resources, and other functions have been added to allow reading and writing of pins etc.
Hello abtj_90
Take a search engine of your choice and ask the WWW for "programming language arduino"
if you have used Python the ESP32 supports MicroPython
it is just Arduino marketing.
In the end you program in c++. The Arduino framework added lot of libraries, functions, definitions, constants,... But in the end it's c++.
it's an hyperbole to not frighten away artists and tell them that they will use a C++ compiler
here's a lengthy discussion
Arduino programs are C++, compiled by gcc.
The reason this question gets asked is because if you examine an Arduino program you will find things that are not mentioned in any pure C++ textbook. This is simply because there are libraries (mostly written in C++) that let you interface to the Arduino or whatever other things you've attached.
It's just like using a database from C++ - there will be a library needed to deal with the API it uses and your C++ text won't mention it most likely.
The Arduino IDE complicates matters a bit. If you use it (you don't have to) It does some textual transformations for you to add main, and some function prototypes, but the output of that is pure C++. Whether you could consider that that preprocessing implies a different language is in use is a philosophical question - personally, I don't think so.
great answers here
