Members
Im confused on what these pin names means?
#define sd_cs ???
#define lcd_cs ???
#define dc ???
#define rst A4 //8
Any help is appreciated. The photo attached is of the underside of the Shield.
Arduino TFT Bitmap Logo example
This example reads an image file from a micro-SD card
and draws it on the screen, at random locations.
In this sketch, the Arduino logo is read from a micro-SD card.
There is a .bmp file included with this sketch.
- open the sketch folder (Ctrl-K or Cmd-K)
- copy the "arduino.bmp" file to a micro-SD
- put the SD into the SD slot of the Arduino TFT module.
This example code is in the public domain.
Created 19 April 2013 by Enrico Gueli
http://www.arduino.cc/en/Tutorial/TFTBitmapLogo
// include the necessary libraries
#include <SPI.h>
#include <SD.h>
#include <TFT.h> // Arduino LCD library
// pin definition for the Uno
#define sd_cs ???
#define lcd_cs ???
#define dc ???
#define rst A4 //8
//SPI Communication
#define LCD_CS A3 //
#define LCD_CD A2
#define LCD_WR A1
#define LCD_RD A0
// optional
#define LCD_RESET A4//
TFT TFTscreen = TFT(lcd_cs, dc, rst);
// this variable represents the image to be drawn on screen
PImage logo;
// initialize the GLCD and show a message
// asking the user to open the serial line
TFTscreen.begin();
TFTscreen.background(255, 255, 255);
TFTscreen.stroke(0, 0, 255);
TFTscreen.println();
TFTscreen.println(F("Arduino TFT Bitmap Example"));
TFTscreen.stroke(0, 0, 0);
TFTscreen.println(F("Open serial monitor"));
TFTscreen.println(F("to run the sketch"));
// initialize the serial port: it will be used to
// print some diagnostic info
//while (!Serial) {
// wait for serial port to connect. Needed for native USB port only
// clear the GLCD screen before starting
// try to access the SD card. If that fails (e.g.
// no card present), the setup process will stop.
Serial.print(F("Initializing SD card..."));
if (!SD.begin(sd_cs)) {
Serial.println(F("failed!"));
return;
Serial.println(F("OK!"));
// initialize and clear the GLCD screen
TFTscreen.begin();
// now that the SD card can be access, try to load the
// image file.
logo = TFTscreen.loadImage("main.bmp");
if (!logo.isValid()) {
Serial.println(F("error while loading arduino.bmp"));
// don't do anything if the image wasn't loaded correctly.
if (logo.isValid() == false) {
return;
Serial.println(F("drawing image"));
// get a random location where to draw the image.
// To avoid the image to be draw outside the screen,
// take into account the image size.
int x = random(TFTscreen.width() - logo.width());
int y = random(TFTscreen.height() - logo.height());
// draw the image to the screen
TFTscreen.image(logo, x, y);
// wait a little bit before drawing again
delay(1500);
Thanks in advance.
