Conn. problems with IMac UNO and ESP
Hi in the cloud with things I tried to let the UNO board be recognized.
It failed even after all suggestions made during the errors.
Secondly this also happened with ESP8266 V3 boards.
If I run the IDE2.3.4 I can program the UNO.
For ESP8266 V3 the provided location link for additional board manager link is not working. http://arduino.esp8266.com/stable/package_esp8266com_jason.index
Hi @snoopy2024.
I'm not sure I understood correctly what you mean by this. Please provide a more detailed description of what you mean by this in a reply on this forum thread to help us to understand it.
Make sure to include the following information:
  • What did you do?
  • What were the results you expected from doing that thing?
  • What were the results you observed that did not match your expectations?
Make sure to include the full and exact text of any error or warning messages you might have encountered.
That is because it is wrong. You must use the URL provided in the official documentation here:
https://github.com/esp8266/arduino#installing-with-boards-manager
Make sure to copy the URL they provide in the documentation exactly.
Dear Sir,
Thank you for coming back so soon.
You are right it was a bit short written, but I am happy to tell that the link that you provided is working.
Make sure to include the following information: Herewith my info:
  • What did you do?
  • Made connection to the cloud with my Mac mini with MacOS Sequoia 15.3.2
  • I started with Cloud project and basically I copied the DHT11 project from Drubasaha than followed the steps correctly and put the secret key in the sketch. Runned the sketch >> Done Verifying Temperature_Control_mar19a a
  • That load would take place to the board without errors.
(Attachment Error in cloud.rtf is missing)
(attachments)
Temperature_Control_mar19a.zip (5.69 KB)
Dear Sir,
What did you do?
That load would take place to the board without errors.That I would see the data coming into Dashboard.
Loading the Sketch failed see attached
Also after switching USB ports I got the same error.
Regards,
Matt
You mention errors, but you haven't described any errors. The only thing you described is the "Done Verifying Temperature_Control_mar19a" notification that indicates the compilation was successful.
If you are encountering errors, then you need to provide a detailed description of those errors.
Maybe you attempted to attach a file named cloud.rtf to your message? If so, it failed.
:red_exclamation_mark: PLEASE DO NOT EVER REPLY TO EMAILS FROM ARDUINO FORUM!!! You must instead come to the forum website and reply via the website interface. This is the only way to make sure that you will effectively communicate with us here on the forum.
Please also always avoid using file attachments if possible. Unnecessary use of attachments is inconsiderate to the forum helpers as it is less convenient for us to have to download a file and open it just to see what it contains so we can assist you. It also makes it less likely that you will get effective assistance as some forum helpers can't or won't download files.
It was somewhat reasonable to attach a ZIP file of your sketch in this case since the sketch contains multiple files. However, it is very rarely reasonable to post any other text content as a file attachment. You should instead paste it directly into your post.
The only exception is when the forum shows you an error that says the post is longer than allowed. In that case you can use an attachment. However, in that case you must use a basic txt file, NOT some inappropriate format like RTF. If you don't already have a real text editor application, then you need to install one as this is an essential tool for anyone writing code. I can recommend the excellent VS Code, but there are many other excellent free open source text editors so feel free to use whichever one you prefer.
Hello Sir,
Herewith the error result after trying to load the sketch.
Sketch uses 424292 bytes (84%) of program storage space. Maximum is 499696 bytes.
Global variables use 36348 bytes (44%) of dynamic memory, leaving 45572 bytes for local variables. Maximum is 81920 bytes.
Flashing with command:/Users/mattvandenberg/.arduino-create/esp8266/esptool/2.5.0-3-20ed2b9/esptool -vv -cd ck -cb 115200 -cp /dev/cu.usbserial-230 -ca 0x00000 -cf /var/folders/1y/1m_5wq3n3m1b5jkjkw6p9m280000gn/T/arduino-create-agent1401312745/Temperature_Control_mar19a.bin
esptool v0.4.13-1-gf80ae31 - (c) 2014 Ch. Klippel ck@atelier-klippel.de
setting board to ck
setting baudrate from 115200 to 115200
setting port from /dev/tty.usbserial to /dev/cu.usbserial-230
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
opening port /dev/cu.usbserial-230 at 115200
tcgetattr
tcsetattr
serial open
opening bootloader
resetting board
trying to connect
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
serialport_receive_C0: 00 instead of C0
trying to connect
trying to connect
resetting board
trying to connect
trying to connect
trying to connect
resetting board
trying to connect
trying to connect
trying to connect
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
Executing command: exit status 2
