Hi there, I'm currently using this(GitHub - MajenkoLibraries/MCPDAC: Library to control the MCP4822 and similar DAC chips) library to do some tests with a MCP4822 and it works great!
Now I would like to connect a second MCP4822 to my project to add 2 extra outputs. Is that possible with this library? I connect it to the same MOSI and CLK. Only the CS of the 2nd MCP is connected to pin 9.
How can I tell my arduino that there is a second DAC connected?
Hi panapro
Assuming you are not using a latch pin on the DACs, so just MOSI, CLK and CS ...
In your program, add this code before setup()
to create a second instance of the DAC object:
MCPDACClass secondDAC;
In setup()
, call begin()
with the pin number of the second CS:
secondDAC.begin(9);
Then, in your program, use secondDAC
instead of MCPDAC
when you set gain, set voltage, etc.
Regards
Ray
Thank you Ray!
It seems that it does the job! I don't get errors in my IDE. Tomorrow I will upload it and let you know.
Edit:
It is working perfect! Thank you very much!
