I was just wondering if there is a way to connect 2 portenta h7 via bluetooth, basically have 2 portenta h7 to communicate to each other via bluetooth, I'm trying to connect them together so that an IR sensor once it detects fire communicates to the other portenta via bluetooth.
Yes, it is possible to connect two Portenta H7 boards via Bluetooth and have them communicate with each other. Here are the general steps you can follow to achieve this:
- Enable Bluetooth on both Portenta H7 boards. You can do this by using the
BLE.begin()
function in your code. Here is an example code snippet:
#include <ArduinoBLE.h>
while (!Serial);
if (!BLE.begin()) {
Serial.println("BLE Failed to Initialize!");
while (1);
Serial.println("BLE Initialized Successfully!");
- Configure one of the Portenta H7 boards as a Bluetooth server, and the other as a Bluetooth client. The server board will advertise its services, and the client board will scan for available servers and connect to the desired one. Here is an example code snippet for the server board:
BLEService fireService("19b10010-e8f2-537e-4f6c-d104768a1214"); // create a BLE service
BLECharacteristic fireCharacteristic("19b10011-e8f2-537e-4f6c-d104768a1214", BLERead | BLENotify); // create a BLE characteristic
while (!Serial);
if (!BLE.begin()) {
while (1);
BLE.setLocalName("Fire Sensor");
BLE.setAdvertisedService(fireService); // add the service UUID
fireService.addCharacteristic(fireCharacteristic); // add the characteristic UUID
BLE.addService(fireService); // add the service
fireCharacteristic.setValue("No fire detected yet."); // set an initial value for the characteristic
BLE.advertise(); // start advertising the service
Serial.println("BLE Server Initialized Successfully!");
// Wait for a central to subscribe to the characteristic
while (!fireCharacteristic.subscribed()) {
delay(10);
// Simulate a fire detection event by changing the value of the characteristic
fireCharacteristic.setValue("Fire detected!");
And here is an example code snippet for the client board:
while (!Serial);
if (!BLE.begin()) {
while (1);
BLE.setLocalName("Fire Detector");
BLE.scanForUuid(fireService.uuid()); // start scanning for the server's service UUID
Serial.println("Scanning for Fire Sensor...");
// Wait for the server to be found
while (!fireCharacteristic) {
BLEDevice peripheral = BLE.available();
if (peripheral) {
// Check if the peripheral has the characteristic we are looking for
if (peripheral.hasCharacteristic(fireCharacteristic)) {
fireCharacteristic = peripheral.characteristic(fireCharacteristic.uuid());
Serial.println("Connected to Fire Sensor!");
// Wait for notifications from the server
fireCharacteristic.subscribe();
while (fireCharacteristic.value() == "") {
delay(10);
Z
