Connect 2 potentiometers and a load cell.
Hi guys, I decided that i will build my own sim racing pedals. I'm goin to use a load cell with hx711 amplifier for the brake pedal and potentiometers for clutch and throttle. Is it possible to connect these 3 elements to a single arduino? thank you
Yes. Where will the output from the Arduino go? Will it go to a PC via USB? If so, the Arduino will need to be a USB host.
Thank you for your answer. I would connect arduino to my pc via usb and use it as a joystick. The only thing I wonder is whether there are enought pins on the arduino to connect those 3 elements or not.
