I have a battery-powered standalone arduino project that stores some data to its SRAM. I will need to connect it to FTDI to upload data to PC. I can't power it down as the content will be lost. So while it's powered by battery, I will connect its RX, TX, GND, RST to the FTDI (basically my deumilanove with its atmega removed). This is ok right now but if I use an FTDI USB cable (FTDI Cable 5V - DEV-09718 - SparkFun Electronics) to tidy my project then I will have to disconnect the 5V on the cable, right? Or otherwise I connect the 5V from my standalone with the 5V on PC the battery may die.
Am I correct? Thanks.
