Hi there guys. I am starting a project which needs to have real time video recognition. I was thinking of utilizing Matlab for that but, receiving the video from a camera module connected to the arduino. What I have been struggling with is to connect a camera to the arduino. I currently own a 600TVL like this one, but I'm not sure if this module is possible for what I intend to do.
Do you have any suggestions of what to do? Do I need an SD card as I have read? What camera module and driver would I need to acquire to successfully get the video to Matlab?
Thank you very much.
I suggest using a RaspberryPi3 instead of an Arduino
CAPTURING VIDEO WITH AN ARDUINO
// VIDEO FRAME CAPTURE FOR ARDUINO //
// CARLOS AGELL - MoviMED - www.movimed.com //
// Version 1.0 (Release) June 3rd 2011 by Carlos Agell (MoviMED) //
// Arduino code based on the example by Michael Krumpus //
// at Nootropic Design. //
// The software dynamically changes the threshold for the analog //
// video acquisition taking advantage of an R2R ladder. As soon as //
// a serial character is received the arduino starts acquisition and //
// sending process over serial. The serial counterpart needs to put //
// together the image by adding all the images and scaling to 255. //
// See LabVIEW counterpart. Processing counterpart will be coded soon //
// TO DO: Improve speed on sending by packing bytes into hex codes //
// it currently sends a single bit per byte. //
#include <TVout.h>
#include <fontALL.h>
#define W 128
#define H 96
TVout tv;
unsigned char x,y,i,j,auxpix,k,cnt,turn;
char s[32];
int firstSensor = 0; // first analog sensor
int inByte = 0; // incoming serial byte
tv.begin(NTSC, W, H);
initOverlay();
initInputProcessing();
tv.select_font(font4x6);
tv.fill(0);
turn=0;
pinMode(A3, OUTPUT);
pinMode(A4, OUTPUT);
digitalWrite(A3, LOW);
digitalWrite(A4, LOW);
void initOverlay() {
TCCR1A = 0;
// Enable timer1. ICES0 is set to 0 for falling edge detection on input capture pin.
TCCR1B = _BV(CS10);
// Enable input capture interrupt
TIMSK1 |= _BV(ICIE1);
// Enable external interrupt INT0 on pin 2 with falling edge.
EIMSK = _BV(INT0);
EICRA = _BV(ISC11);
void initInputProcessing() {
// Analog Comparator setup
ADCSRA &= ~_BV(ADEN); // disable ADC
ADCSRB |= _BV(ACME); // enable ADC multiplexer
// ADMUX &= ~_BV(MUX0); // select A2 for use as AIN1 (negative voltage of comparator)
// ADMUX |= _BV(MUX1);
// ADMUX &= ~_BV(MUX2);
ADMUX &= ~_BV(MUX2); // select A1 for use as AIN1 (negative voltage of comparator)
ADMUX &= ~_BV(MUX1);
ADMUX |= _BV(MUX0);
ACSR &= ~_BV(ACIE); // disable analog comparator interrupts
ACSR &= ~_BV(ACIC); // disable analog comparator input capture
ISR(INT0_vect) {
display.scanLine = 0;
tv.capture();
if (Serial.available()>0){
for(k=0;k<8;k++){
//set the threshold
PORTC &= ~(7 << 3);
PORTC |= (k << 3);
//Acquire
tv.capture();
//send
for (j=0;j<H;j++)
for (i=0;i<W;i++)
Serial.print(tv.get_pixel(i,j),HEX);
inByte = Serial.read();
PORTC &= ~(7 << 3);
PORTC |= (turn << 3);
//turn = (turn+1)%4;
turn = (turn+1)%8;
tv.resume();
tv.delay_frame(5);
I don't think an Arduino has anything near the processing power needed to do video recognition. A Pi may be pushing it already.
JoaoSantos12:
Your requirements contradict themselves. You want realtime video recognition, what ever that is, at the same time your want to move a frame of video data from device to device that may take days.
Paul
