Connect a sensor chip
I want to know how to connect this sensor to arduino https://www.sparkfun.com/products/10937. The idea is connect to a protoboard with a cable and do other things if needed. I don't want to weld it, i will do it in the future in a PCB.
I don't know what parts of the chip i need to connect to the proto.
The most practical way to connect a surface-mount IC to an Arduino is to buy it mounted on a breakout board:
https://www.sparkfun.com/products/11028
johnwasser: The most practical way to connect a surface-mount IC to an Arduino is to buy it mounted on a breakout board:
But is possible connect without it. Connecting the capacitators on the breadboard an connect the chip with a cable.
charlesblack:
The determinator is whether the pins on the chip match up with the board's contact matrix (it probably won't). It will be much simpler to buy a prototyping board like https://www.sparkfun.com/products/7914 and as Johnwasser alluded, mount a breakout board with the chip on it. Then attach to the Arduino.
charlesblack: But is possible connect without it. Connecting the capacitators on the breadboard an connect the chip with a cable.
The chip is 4mm by 4mm and has 28 pins. If you can solder wires to the pins you need then, yes, you can connect the chip by wires to a breadboard.
Just buy a completed module.
http://www.ebay.com/itm/6DOF-MPU-6050-Accelerometer-Gyroscope-3-Axis-Gyro-Module-3-3V-5V-for-Arduino-DIY-/390620036060?pt=LH_DefaultDomain_2&hash=item5af2c4bbdc
//Per
Do you know how big 4 millimetres is ?
