Connect an Arduino UNO to PC Via Arduino MEGA
Hi folks,
so I have a big problem with getting this sorted out.
I am running an UNO connected to the PC via USB and it communicates with a train simulator, simply makes a LED go on when someting happens in the game.
This is the code:
volatile uint8_t zPC[52] = {0};
volatile uint8_t doPC[20] = {0xEF, 0xEF, 0xEF, 0xEF, 0};
pinMode(13, OUTPUT);
digitalWrite(13, LOW);
Serial.setTimeout(10);
while(!Serial){};
digitalWrite(13, (bitRead(zPC[9], 5)));
while (!Serial.available()) {};
Serial.readBytes((char*)zPC, 52);
Serial.write((char*)doPC, 20);
But I also have an Arduino MEGA with more functions for the simulator.
I want the MEGA to be connected via USB to the PC and the UNO to be connected with the MEGA via UART Serial2.
How to code this?
Both of them use the uint8_t when they are directly connected with the PC.
Thanks!
Why not combine the code, put it on the Mega and use that ?
I am planning a module contruction. I also want to learn the logic of the serial communication.
There is no reason why ArduinoA should not pass data to ArduinoB via a Serial link and then have ArduinoB pass it on to the PC along with data directly from ArduinoB
Where are you stuck ?
I don't know how to write the Serial parameters to connect them together.
In the MEGA (which is connected via USB to PC) I should have:
Serial2.begin(9600)
and what else? What else should I have?
Serial2.read()?
How do you normally send the data to the PC from the Mega ? That will not change
To get the data from the Uno to the Mega you "print" it to a serial port (see below) and on the Mega you read it on a Serial port when it becomes available
You cannot sensibly use the normal Serial port on the Uno because it is used by the Serial monitor and to upload to the PC so will need to use SoftwareSerial on any pins except 0 and 1. There are examples in the IDE
To receive the data on the Mega you should use one of its serial ports other than Serial, ie Serial1, Serial2 or Serial3 and connect the data leads from the Uno to the associated pins on the Mega
The baud rates on the Uno and Mega must match and there must be a common GND connection between them
Basically you print data on the Uno, read it on the Mega and once read print it to the PC
Ok, great! So how do I get the code in the UNO to print it to MEGA.
Like this:
while(!Serial){};
Serial.print();
On the Uno you do something like this
#include "SoftwareSerial.h"
SoftwareSerial toMega(10, 11);  //Rx and Tx pins of your choice
  toMega.begin(9600);  //start the interface to the Mega
  toMega.println("Hello Mega");  //send data to the Mega
You can send any data type that you like to the Mega by "printing" it but parsing it on the Mega can be "interesting"
Could you help me to convert this code to work with the uint8_t from the PC?
What I want to do in the code is to read the data bytes from the PC via the ARDUINO MEGA and make the connected ARDUINO UNO react to this with digitalWrite(13, HIGH).
How to do it?
Now it seems that you want the Uno to do something with data from the PC. Is that right ?
Please describe exactly how you envisage the data flowing from the Uno to the Mega then to the PC and from the PC to the Mega to the Uno
Examples of the data would also be helpful
Yes, exactly. I want the UNO connected via the MEGA to the PC to work with the PC data.
In the UNO I want to read the following parameters:
digitalWrite(13, (bitRead(zPC[9], 5))); // This "zPC" is from the uint8_t table and reffers to the byte [9] and bit [5].
I want to read them through the MEGA connected with the PC via USB.
In the same way that the Uno can send data to the Mega and the Mega can pass it on to the PC the Mega can receive data from the PC and pass it on to the Uno
Don't try to write this all in one go. Start with the code in reply #8 and get the Uno passing data to the Mega. When it is received on the Mega just print it. When you have got that working have the Mega pass it on to the PC and print it in the Serial monitor
Ok I will try step by step.
Thanks for help!
What is this train simulator? Is there a specification of the communication protocol for it? Does it always send 52 bytes? Does it always expect 20 bytes as a reply?
How many modules will be connected to the Mega (think future)? You only have three additional serial ports available on the Mega.
This reads: wait till one or more bytes are available and regardless wether 1, 2, ... or 52 bytes are available read 52 bytes. So what happens if there are less than 52 bytes available?
Why do you cast to a char pointer? doPC is a byte array, you should be able to send that directly without a cast.
Why are those variables declared as volatile?
there is no specification of the communication protocol for it. A few guys asked the developers to make the possibility to connect the sim to external devices and then made the code for Arduino. I don't know why is it like this, but it works.
I am planning max 2 external UART modules.
I am really confused because I do understand the code for communicating with the PC but I don't know how to get 2 Arduinos work together in order to do it.
Can you post your Mega code as well. Please use code tags (the </> button here in the reply window) to make it easier to copy.
Can you post a link to where you got your information from?
Are you prepared to do a bit of reverse engineering? So we can see what the train simulator actually sends and maybe design a solution around that.
Serial communication between 2 Arduinos is the same as communication between an Arduino and the PC
In the latter case the Arduino transmits some data via Serial.print() or Serial.write(), it is received by the PC and used, maybe just written to the Serial monitor. Data in the other direction is sent from the PC, received by the Arduino then used to do something
Arduino to Arduino Serial communication is exactly the same except that you substitute a second Arduino for the PC
