Connect arduino uno or nano to a battery pack
Hey I'm doing a prop project, I have arduino nano board and adafruit 24LED ring. But I need to connect arduino to a portable battery. So I have battery pack wich output voltage 10.8 - 12.6V DC and output current is 1-2A.
Just to be clear I need to connect positive side to Vin and ground to any ground pin?
And is it safe to connect 12,6V to arduino nano or arduino uno?
Thanks!
I connected an adafruit ring and a Uno to an inexpensive USB power bank.
Super easy. Portable.
vinceherman:
I would do that too, but i don't have a battery bank. I have battery pack like this
http://www.ebay.com/itm/1800-15000mAh-DC-12V-Rechargeable-Portable-Super-Li-ion-Battery-Plug-/182674908461?var=&hash=item2a8845e52d
Karolis:
  1. Yes, but...
  2. You can't power anything from the Nano's 5volt pin at that input voltage.
    And very little (<100mA) from the Uno.
    A 24-LED ring (1.3Amp) would fry both.
You need a 5volt buck converter (>=2A) for this setup.
With it's output directly connected to the LED ring and the 5volt pin of the Nano.
Leo..
I use cheap cigarette lighter USB chargers from China. They cost one or two bucks and otherwise turn a wide variety of voltages into 5 volts using a wee buck converter. Many come with a blue light.
