connect arduino uno to pc via bluetooth
hello i am an 2nd year electronic student and for my telecom lectural i want to make a shield that help sending programm to my arduino uno using bluetooth and i do no really know where to start.
i have seen this schematic
// arduino bluetooth //that i want to make (since i must make the shield myself) but i intent to buy this bluetooth module(cause there is no way that i can weld the chip use there myself)
can someone please help me i kind of lost please =( =( =(
I don't think you know what you want but, whatever it is, you can safely forget about the schematic. The module you refer to is a common HC-0x module on a back board. This may be connected to your Arduino simply by using four male/female jumpers. If you really need to make a shield you could get a small prototyping shield kit and fix the same module to that. Only four connections are needed. Other than for the intellectual exercise, I don't know why you would bother, unless you can think of other uses for the proto shield, and then it's not uncommon to use flying leads for the Bluetooth anyway.
This background might be useful
http://homepages.ihug.com.au/~npyner/Arduino/GUIDE_2BT.pdf
http://homepages.ihug.com.au/~npyner/Arduino/BT_2_WAY.ino
