Hello there, I would really like some help connecting my Arduino UNO with a motorcontroller (http://goo.gl/JkAQo), DC motor and a battery.
Can someone please tell me where to connect the different components?
Sorry for not getting back before now. But I've havn't had the time to really make sure I was doing everything right.
I found your reply very clear, but for some reason I can't get it working.
Here's a picture of the setup: http://goo.gl/9ihqq
I have connected everything as you said, and the yellow and red LED shows that the power sources are working.
The current status is PWMA: High, AIN1: HIGH, AIN2: LOW, STBY: HIGH, but AO1 and AO2 doesn't output anything. (everything is measured with a multimeter.
Any idea what could be wrong?
I've updated the image of the setup here: http://goo.gl/TLCsm
EDIT: close up: http://goo.gl/8L0NE
Here's the code for the arduino. It's very simple and bolied down to the basics.
#define AIN1 7
#define AIN2 8
#define PWMA 3
pinMode(AIN1, OUTPUT);
pinMode(AIN2, OUTPUT);
pinMode(PWMA, OUTPUT);
digitalWrite(AIN1, LOW);
digitalWrite(AIN2,HIGH);
digitalWrite(PWMA, HIGH);
I do not have a motor connected because it thougt it would be easier to debug without. AO1 and AO2 are just loose, and then I use my multimeter to measure if there is any output.
thank you very much for your feedback.
I've never tried making a circuit scematic diagram before, but here's my first attempt. I'll try unclutter as much as I can.
I know that it looks like some wires are connected, but unless theres a yellow dot they are not.
