Connect Arduino Yun to 3g Dongle
I followed following link.
http://selfbuilt.net/wiki/doku.php?id=arduino_yun_mobile_networks
when connect SMARTONE in network ---> interface,it showing following error
19:00:28 yun authpriv.notice dropbear[1387]: Password auth succeeded for 'root' from 192.168.0.2:37810
19:00:29 yun user.notice usb-modeswitch: 1-1.1.2:1.0: Manufacturer=ZTE,Incorporated Product=ZTE_CDMA_Technologies_MSM Serial=?
19:00:29 yun user.notice usb-modeswitch: 1-1.1.2:1.1: Manufacturer=ZTE,Incorporated Product=ZTE_CDMA_Technologies_MSM Serial=?
19:00:29 yun user.notice usb-modeswitch: 1-1.1.2:1.2: Manufacturer=ZTE,Incorporated Product=ZTE_CDMA_Technologies_MSM Serial=?
19:00:30 yun daemon.notice netifd: wan2 (1801): comgt 19:00:30 -> -- Error Report --
19:00:30 yun daemon.notice netifd: wan2 (1801): comgt 19:00:30 -> ----> ^
19:00:30 yun daemon.notice netifd: wan2 (1801): comgt 19:00:30 -> Error @114, line 9, Could not write to COM device. (1)
19:00:32 yun daemon.notice netifd: wan2 (1801): Trying to set PIN
19:00:33 yun daemon.notice netifd: wan2 (1801): PIN set successfully
19:00:33 yun daemon.notice pppd[1894]: pppd 2.4.5 started by root, uid 0
19:00:34 yun local2.info chat[1898]: abort on (BUSY)
19:00:34 yun local2.info chat[1898]: abort on (NO CARRIER)
19:00:34 yun local2.info chat[1898]: abort on (ERROR)
19:00:34 yun local2.info chat[1898]: report (CONNECT)
19:00:34 yun local2.info chat[1898]: timeout set to 10 seconds
19:00:34 yun local2.info chat[1898]: send (AT&F^M)
19:00:34 yun local2.info chat[1898]: expect (OK)
19:00:34 yun local2.info chat[1898]: ^M
19:00:34 yun local2.info chat[1898]: +ZDONR: "Not Found"^M
19:00:34 yun local2.info chat[1898]: +ZPASR: "No Service"^M
19:00:34 yun local2.info chat[1898]: AT&F^M^M
19:00:34 yun local2.info chat[1898]: OK
19:00:34 yun local2.info chat[1898]: -- got it
19:00:34 yun local2.info chat[1898]: send (ATE1^M)
19:00:34 yun local2.info chat[1898]: ATE1^M^M
19:00:34 yun local2.info chat[1898]: send (AT+CGDCONT=1,"IP","tre.it"^M)
19:00:34 yun local2.info chat[1898]: send (AT+SYSCFG=2,2,3FFFFFFF,0,4^M)
19:00:35 yun local2.info chat[1898]: timeout set to 30 seconds
19:00:35 yun local2.info chat[1898]: expect (OK)
19:00:35 yun local2.info chat[1898]: ^M
19:00:35 yun local2.info chat[1898]: AT+CGDCONT=1,"IP","tre.it"^M^M
19:00:35 yun local2.info chat[1898]: OK
19:00:35 yun local2.info chat[1898]: -- got it
19:00:35 yun local2.info chat[1898]: send (ATD*99#^M)
19:00:35 yun local2.info chat[1898]: expect (CONNECT)
19:00:35 yun local2.info chat[1898]: AT+SYSCFG=2,2,3FFFFFFF,0,4^M^M
19:00:35 yun local2.info chat[1898]: ERROR
19:00:35 yun local2.info chat[1898]: -- failed
19:00:35 yun local2.info chat[1898]: Failed (ERROR)
19:00:35 yun daemon.err pppd[1894]: Connect script failed
19:00:46 yun daemon.info pppd[1894]: Exit.
19:00:46 yun daemon.notice netifd: Interface 'wan2' is now down
19:02:24 yun daemon.notice netifd: wan2 (1968): comgt 19:02:24 -> -- Error Report --
19:02:24 yun daemon.notice netifd: wan2 (1968): comgt 19:02:24 -> ----> ^
19:02:24 yun daemon.notice netifd: wan2 (1968): comgt 19:02:24 -> Error @152, line 10, Could not write to COM device. (1)
what it means.
pothina_bala:
::::SNIP::::
what it means.
@pothina,
It means it is not working.
Jesse
for connecting USB Dongle I got Following error and i followed this tutorial:
http://wiki.linino.org/doku.php?id=wiki:lininousbmodem
Error Message:
root@Arduino:~# logread
un 29 11:03:37 Arduino user.notice usb-modeswitch: 1-1.1:1.6: Manufacturer=? Product=? Serial=?
un 29 11:03:42 Arduino kern.info kernel: [ 5929.080000] usb 1-1.1: new high-speed USB device number 49 using ehci-platform
Jun 29 11:03:42 Arduino kern.info kernel: [ 5929.210000] usb 1-1.1: New USB device found, idVendor=12d1, idProduct=14fe
Jun 29 11:03:42 Arduino kern.info kernel: [ 5929.210000] usb 1-1.1: New USB device strings: Mfr=3, Product=2, SerialNumber=5
Jun 29 11:03:42 Arduino kern.info kernel: [ 5929.220000] usb 1-1.1: Product: HUAWEI Mobile
Jun 29 11:03:42 Arduino kern.info kernel: [ 5929.220000] usb 1-1.1: Manufacturer: HUAWEI Technology
Jun 29 11:03:42 Arduino kern.info kernel: [ 5929.230000] usb 1-1.1: SerialNumber: FFFFFFFFFFFFFFFF
Jun 29 11:03:42 Arduino kern.info kernel: [ 5929.240000] scsi60 : usb-storage 1-1.1:1.0
Jun 29 11:03:43 Arduino user.notice usb-modeswitch: 1-1.1:1.0: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=FFFFFFFFFFFFFFFF
Jun 29 11:03:43 Arduino user.notice usb-modeswitch: 1-1.1:1.0: Selecting /etc/usb_modeswitch.d/12d1:14fe for mode switching
Jun 29 11:03:43 Arduino syslog.notice usb_modeswitch: switching device 12d1:14fe on 001/049
Jun 29 11:03:43 Arduino kern.info kernel: [ 5929.610000] usb 1-1.1: USB disconnect, device number 49
Jun 29 11:03:43 Arduino kern.info kernel: [ 5929.850000] usb 1-1.1: new high-speed USB device number 50 using ehci-platform
Jun 29 11:03:43 Arduino kern.info kernel: [ 5929.980000] usb 1-1.1: New USB device found, idVendor=12d1, idProduct=1506
Jun 29 11:03:43 Arduino kern.info kernel: [ 5930.000000] option 1-1.1:1.3: GSM modem (1-port) converter detected
Jun 29 11:03:43 Arduino kern.info kernel: [ 5930.010000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0
Jun 29 11:03:43 Arduino kern.info kernel: [ 5930.020000] scsi61 : usb-storage 1-1.1:1.5
Jun 29 11:03:43 Arduino kern.info kernel: [ 5930.020000] scsi62 : usb-storage 1-1.1:1.6
Jun 29 11:03:44 Arduino kern.notice kernel: [ 5931.020000] scsi 61:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Jun 29 11:03:44 Arduino kern.notice kernel: [ 5931.030000] scsi 62:0:0:0: Direct-Access HUAWEI TF CARD Storage 2.31 PQ: 0 ANSI: 2
Jun 29 11:03:44 Arduino kern.notice kernel: [ 5931.040000] sd 62:0:0:0: [sdb] Attached SCSI removable disk
Jun 29 11:03:49 Arduino kern.info kernel: [ 5936.260000] usb 1-1.1: USB disconnect, device number 50
Jun 29 11:03:49 Arduino kern.info kernel: [ 5936.270000] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Jun 29 11:03:49 Arduino kern.info kernel: [ 5936.270000] option 1-1.1:1.3: device disconnected
Jun 29 11:04:01 Arduino kern.info kernel: [ 5947.510000] usb 1-1.1: new high-speed USB device number 51 using ehci-platform
Jun 29 11:04:01 Arduino kern.info kernel: [ 5947.640000] usb 1-1.1: New USB device found, idVendor=12d1, idProduct=14fe
Jun 29 11:04:01 Arduino kern.info kernel: [ 5947.660000] usb 1-1.1: SerialNumber: FFFFFFFFFFFFFFFF
Jun 29 11:04:01 Arduino kern.info kernel: [ 5947.680000] scsi63 : usb-storage 1-1.1:1.0
Jun 29 11:04:58 Arduino user.notice usb-modeswitch: 1-1.1:1.4: Switching seemingly failed
Jun 29 11:04:59 Arduino user.notice usb-modeswitch: 1-1.1:1.5: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=FFFFFFFFFFFFFFFF
Jun 29 11:04:59 Arduino user.notice usb-modeswitch: 1-1.1:1.5: Selecting /etc/usb_modeswitch.d/12d1:14fe for mode switching
Jun 29 11:04:59 Arduino user.notice usb-modeswitch: 1-1.1:1.5: Switching seemingly failed
Jun 29 11:05:00 Arduino user.notice usb-modeswitch: 1-1.1:1.5: Switching seemingly failed
Jun 29 11:05:06 Arduino user.notice usb-modeswitch: 1-1.1:1.6: Selecting /etc/usb_modeswitch.d/12d1:14fe for mode switching
Jun 29 11:05:06 Arduino user.notice usb-modeswitch: 1-1.1:1.6: Switching seemingly failed
Jun 29 11:05:16 Arduino user.notice usb-modeswitch: 1-1.1:1.0: Selecting /etc/usb_modeswitch.d/12d1:14fe for mode switching
Jun 29 11:05:16 Arduino syslog.notice usb_modeswitch: switching device 12d1:14fe on 001/051
Jun 29 11:05:16 Arduino kern.info kernel: [ 6022.540000] usb 1-1.1: USB disconnect, device number 51
Jun 29 11:05:16 Arduino kern.info kernel: [ 6022.900000] usb 1-1.1: new high-speed USB device number 52 using ehci-platform
Jun 29 11:05:16 Arduino kern.info kernel: [ 6023.030000] usb 1-1.1: New USB device found, idVendor=12d1, idProduct=1506
Jun 29 11:05:16 Arduino kern.info kernel: [ 6023.030000] usb 1-1.1: New USB device strings: Mfr=3, Product=2, SerialNumber=0
Jun 29 11:05:16 Arduino kern.info kernel: [ 6023.040000] usb 1-1.1: Product: HUAWEI Mobile
Jun 29 11:05:16 Arduino kern.info kernel: [ 6023.050000] usb 1-1.1: Manufacturer: HUAWEI Technology
Jun 29 11:05:16 Arduino kern.info kernel: [ 6023.060000] option 1-1.1:1.3: GSM modem (1-port) converter detected
Jun 29 11:05:16 Arduino kern.info kernel: [ 6023.070000] usb 1-1.1: GSM modem (1-port) converter now attached to ttyUSB0
Jun 29 11:05:16 Arduino kern.info kernel: [ 6023.080000] scsi64 : usb-storage 1-1.1:1.5
Jun 29 11:05:16 Arduino kern.info kernel: [ 6023.080000] scsi65 : usb-storage 1-1.1:1.6
Jun 29 11:05:17 Arduino kern.notice kernel: [ 6024.080000] scsi 64:0:0:0: CD-ROM HUAWEI Mass Storage 2.31 PQ: 0 ANSI: 2
Jun 29 11:05:17 Arduino kern.notice kernel: [ 6024.100000] sd 65:0:0:0: [sdb] Attached SCSI removable disk
Jun 29 11:05:49 Arduino user.notice usb-modeswitch: 1-1.1:1.6: Manufacturer=HUAWEI_Technology Product=HUAWEI_Mobile Serial=?
Jun 29 11:06:56 Arduino daemon.notice pppd[7278]: pppd 2.4.5 started by root, uid 0
Jun 29 11:06:57 Arduino local2.info chat[7292]: abort on (BUSY)
Jun 29 11:06:57 Arduino local2.info chat[7292]: abort on (NO CARRIER)
Jun 29 11:06:57 Arduino local2.info chat[7292]: abort on (ERROR)
Jun 29 11:06:57 Arduino local2.info chat[7292]: report (CONNECT)
Jun 29 11:06:57 Arduino local2.info chat[7292]: timeout set to 10 seconds
Jun 29 11:06:57 Arduino local2.info chat[7292]: send (AT&F^M)
Jun 29 11:06:57 Arduino local2.info chat[7292]: expect (OK)
Jun 29 11:07:07 Arduino local2.info chat[7292]: alarm
Jun 29 11:07:07 Arduino local2.info chat[7292]: Failed
Jun 29 11:07:07 Arduino daemon.err pppd[7278]: Connect script failed
Jun 29 11:07:08 Arduino daemon.info pppd[7278]: Exit.
root@Arduino:~#
Please help me.
pothina_bala:
::::SNIP::::
Please help me.
@pothina_bala,
what do you need help with.
Jesse
